Author Topic: What did you do to your Royal Enfield today?  (Read 1834103 times)
0 Members and 6 Guests are viewing this topic.
b.sheets
Reply #3240 on: August 15, 2013, 12:31:08 am
Changed the spark plug and spark plug cap with NGK brand, what a surprise to me, no more cutoff at idle, no more back firing, no more abrupt throttle, no more cursing when all that happen, can't be more happy with only $14 spend.   ;D ;D
how hard was it to do the spark plug cap?
I've never attempted it before...but I've been wanting to use the NGK cap as well.
2012 C5 Special(SOLD)
2013 Triumph Thruxton
Reply #3241 on: August 15, 2013, 01:14:06 am
Easy peasy. Twist on twist off. The spark plug cap has a tiny "screw" inside that the wire "threads" itself onto.
 Resistor plugs are not needed in my bike ('06 Iron Barrel) as the plug cap has an internal resistor of its own.
Sectorsteve
Reply #3242 on: August 15, 2013, 11:46:20 am
wheel alignment using eyes and 2 lasers. i think we have lift off!
Royal Stargazer
  • I have no idea what I'm doing.
Reply #3243 on: August 17, 2013, 06:05:35 pm
Got that first oil change.
Then they told me I could take her on the highway.
So I did.
 8)
2020 Royal Enfield Continental GT, A racer for more than just cafes
2005 Volvo S60 2.5T AWD, Two doors too many
2003 Royal Enfield Bullet, two-wheeled time machine
Reply #3244 on: August 17, 2013, 08:32:20 pm
Stripped a used TM32 I'm going to put on the Bullet and soaked it in Lestoil to give it a dark grey, parkerized look.  Soaked a couple of hours, rinsed in volumous flow of hot water, soaked with WD-40.  Looks like the old M-16s with the Phosphatized receivers.  Should look  appropriate on a Military Iron Barrel.
Reply #3245 on: August 17, 2013, 09:49:35 pm
That sounds seriously cool!  Pics?!
Reply #3246 on: August 18, 2013, 05:18:48 am
Lousy cell phone pics will have to do for now.
Reply #3247 on: August 18, 2013, 10:27:26 am
What the... the carb in those pics looks totally faked, like old colorized b&w pics.  Very cool.  This is the first I've heard of somebody using a cleaner in order to obtain a certain color!
Reminds me of when I used Pine-sol to clean my BMW carbs - I was clueless, and the person instructing me fail to mention that I should dilute it with water.  I was afraid I killed them; they went super-dull battleship-gray, and lots of gunk (oxidized material?) sloughed off when I tried to clean them:
Cleaned up and ran good in the end, though:
Not sure if these pics will stay, but it doesn't matter...
« Last Edit: August 18, 2013, 10:36:35 am by mattsz »
wildbill
Reply #3248 on: August 18, 2013, 11:50:08 am
unfortunately i was getting a vast number of false neutrals so i checked the clutch play. once i adjusted it back from 5mm to 2mm or just half a turn on the adjustment nut - things improved dramatically.
Reply #3249 on: August 18, 2013, 02:52:35 pm
They stayed.  Way cool!
Don't leave them too long or the Pinesol will eat them.
I was going to paint it with OD Green Lauer Duracoat two part epoxy paint, but decided the Pinesol is less work.
« Last Edit: August 18, 2013, 03:03:28 pm by D the D »
Reply #3250 on: August 18, 2013, 04:31:33 pm
D the D -  That is awesome!  I think I might do that to my Amal for the Blackhawk.  I was actually thinking of either polishing it or painting it black, but that just looks cool as shit!  Is the coating durable or does it wear off?
Reply #3251 on: August 18, 2013, 07:24:57 pm
It's fairly durable. It'll wear off of rubbing surfaces and can be polished off.  I use a toothbrush to clean the parts when I scrub the Lestoil off and it doesn't remove it.  It gets harder after a day.  A carb isn't handled much and doesn't rub on anything so it should last a long time.
rvcycleguy
Reply #3252 on: August 18, 2013, 07:28:08 pm
Took the bike out for its weekly ride.   On the way back I was still 15 miles from home and the bike developed a heavy vibration.  Couldn't make it out, hard to check it while riding.  Performance was not affected and the gearing seemed to be ok.  Vibration increased with rpm's. Thought it might be the chain, so I started to take it easy to get home.  Came to a highway stoplight and the bike died.  Low idle I guess.  Pushed it out of traffic and started to kick start it.  Took a couple of kicks and then when it started, I heard a metal sound hit the ground.  Looked down and saw a 3inch bolt?  Was this from my bike?  Looked underneath the gas tank and sure enough, the upper engine mount bolt was missing.  Wow,  must have vibrated off on the ride today.  With the bolt now in my pocket, vibration was worse.  Took it very slow the last few miles to get home.  I'll have to get me a lock nut and replace the bolt.  Interesting day.
Reply #3253 on: August 18, 2013, 08:03:33 pm
Fantastic !!
Would you please give a few details of the process for the good of the order.
Reply #3254 on: August 18, 2013, 08:27:23 pm
Fantastic !!
I placed the subject on the kitchen counter, touched the camera app icon, pointed the phone, and pressed the iris icon.  The focus and flash were automatic.
