my bike in trip ooty
37 Guests, 1 User
kodai
April 29, 2016, 01:08:23 am
Author Topic: What did you do to your Royal Enfield today?  (Read 354047 times)
hillntx
  • Shriner Bulleteer
  • 2011 C5 Classic
« Reply #2220 on: September 28, 2012, 07:45:28 pm »
I just looked at mine and wondered if there is an iron barrell bullet out there that does not leak.
It's just trying to mark it's territory...
« Reply #2221 on: September 28, 2012, 08:24:28 pm »
Yes, there are Iron Barrel Bullets out there that don't leak.
Where is yours leaking?
FiRE Comms
  • '11 C5
« Reply #2222 on: September 28, 2012, 08:58:54 pm »
parked and put up the bike, and heading off to another job, not going to be able to ride again until March...
Chris
jartist
« Reply #2223 on: September 29, 2012, 12:22:58 am »
Dude, that bites! There's always youtube clips to get the Enfield thump fix but it's just not the same.
« Reply #2224 on: September 29, 2012, 04:15:55 am »
Speaking of the "Enfield thump", how many miles do I need to put on mine before I hear it?  800 so far, and I'm just not gettin' any.  Still idles too high, too.  If ADB's "before" video (D+D Exhaust thread: http://www.youtube.com/watch?v=_wJHHdihXCg&feature=plcp) is a proper indicator, I may have an impostor...
1 Thump
« Reply #2225 on: September 29, 2012, 09:04:15 pm »
The primary leaks. I may have overtightened it. Whats the recommended torque spec for that.
bikerboo
  • 2011 Classic
« Reply #2226 on: September 30, 2012, 12:55:13 pm »
mounted a rescue mission on mine to recover him from where I had to dump him yesterday after he broke down.Luckily I had my mate with me so at least I got a ride home on a Tiger 90.So its off to the dealer again for "Stan".Hope its just a loose wire and nothing too traumatic.Just when things were going so well.
Adventure before dementia
« Reply #2227 on: September 30, 2012, 01:29:54 pm »
The primary cover on the iron barrel bikes is held by one nut in the middle.
It is VERY important to not over-tighten that nut, because it might warp the cover and then it will never seal.
Remove the cover, clean the large o-ring that seals the circumference, and remove it for cleaning if necessary. Don't stretch it, or you'll need a new one.
Grease the whole o-ring with axle grease, and maybe put a little in the o-ring grooves too, and that acts as a sealant, believe it or not.
Tighten it up to about 10 foot pounds and see if that holds the oil, maybe 15 foot-pounds if you need to tighten it. That's that should do it.
If that doesn't do it, then you have a warped cover or a bad o-ring, or something like that.
« Reply #2228 on: September 30, 2012, 02:18:27 pm »
I got  my short problem eliminated, hopefully cured, as I never did find a definitive short. I did find several bare wire bits that could've caused the short. I fixed those and did some wire rerouting so the wires aren't as tight as a G string. I pulled a lot of connectors apart to try to find a short. I checked my alternator output and the R/R condition. They all passed.
I shortened my fuel line so it doesn't ride of top of the side cover. Just a big general once over. I took it for about a half hour ride and didn't have any problems, so now all I have to do is wait for the weather to cool off again and  do another epic ride.
Lady_Enfield
  • Bluce
« Reply #2229 on: October 01, 2012, 12:08:25 am »
I relented and took her to a real mechanic....sad day.  Never could get the problem ironed out. :'(
I am Multi-FUNctional!
JVS
  • I love chicken
« Reply #2230 on: October 01, 2012, 12:43:04 am »
Removed the passenger back-rest off the stock seat and this is how it looks -
« Reply #2231 on: October 01, 2012, 01:48:53 am »
This must be the longest running thread ever on this forum
FiRE Comms
  • '11 C5
« Reply #2232 on: October 01, 2012, 01:59:35 am »
and a wealth of information
Chris
« Reply #2233 on: October 01, 2012, 02:27:57 am »
I checked the stats and it is by far the longest running thread
« Reply #2234 on: October 01, 2012, 10:28:53 pm »
You mentioned that you found some bare wires that might have caused your short.
Where were they in case I run out of things to do and want to look to see if mine are also damaged?
