Author Topic: What did you do to your Royal Enfield today?  (Read 1845782 times)
0 Members and 3 Guests are viewing this topic.
AmBraCol
  • Rebelling Against The Rebels
Reply #6060 on: November 10, 2015, 03:13:29 pm
I warmed up the engine before wheeling the Rumbler out of the garage and made sure to set her properly so she wouldn't lay down on me again while locking the door.  Then I rode her.  After my appointment I rode her again, talking the long way home.  Today we broke 300, getting clear up to 319 km on the odometer before I parked in front of the house.  Oh, and yesterday I took my wife to work on the Rumbler.  She told me that it's FAR MORE COMFORTABLE than the old XL 200 was.  :)
Paul
2015 Royal Enfield Rumbler 500
longstrokeclassic
Reply #6061 on: November 10, 2015, 09:45:48 pm
Cleaned the points and checked the gap, checked the sparking plug, adjusted the idle mixture, re checked the sparking plug, adjusted the front brake cable and then cleaned the headlight connections.
 You C5 and G5 guys might consider picking up an Iron Barrel like mine so you can have some maintenance fun too.
 Wished for a G5.
I think we're gonna be in trouble when our EFI's come prefilled with lifetime oil and filters
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
AmBraCol
Reply #6062 on: November 11, 2015, 03:28:17 pm
On a quick ride down to "Carthage" and back I hit an indicated 100 kmh for the first time.  The tach reads right at 3600 rpm at that speed in fifth gear.  And it's smooth at that speed, much smoother than I'd been lead to expect. The run in process continues, this was the first four lane highway jaunt, although our four-lanes are nothing to compare to the ones up in the U.S. of A. Most traffic is between 70 - 80 kmh with the occasional person in a hurry zipping past at 120 kmh. So varying from 50 to 80 for the most part with the bump up to 100 was no problem at all, just watch the traffic flow and stay awake to what the other guy is doing, both the one in front and the one overtaking from behind.
Paul
ToesNose
  • That goes where? Mooresville, NC
Reply #6063 on: November 11, 2015, 03:39:25 pm
Beautiful crisp morning to ride into work.......bike died again LOL.  I thought I found the electrical Gremlin, but I guess not. Probably just a short somewhere HEH. At least with the kick start I can turn the headlight off and get where I need to go  ;)
"Pardon me...do you have hot sauce for this?"
2007 Suzuki LS650
2014 RE C5 Tan 'Manjika'
gremlin
Reply #6064 on: November 11, 2015, 10:21:25 pm
decorated the battery box for B5
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Reply #6065 on: November 11, 2015, 11:32:48 pm
Gremlin - I can see you spent a lot of time on that mod!  ;)
Now I gotta update my avatar!  :(
gremlin
Reply #6066 on: November 12, 2015, 01:23:49 am
Amazon.com  5 inch decal from "Nostalgia Decals Super Store" for $3.50 (shipping included) 20 minutes with a razorblade to remove the OEM sticker, a bit of alcohol wash for the part, a bit of alcohol wash for me ...... and a couple passes of Krylon clear coat from a spraycan.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Reply #6067 on: November 12, 2015, 03:03:34 am
The alcohol wash part sounds good... at least the second one does!
AmBraCol
Reply #6068 on: November 27, 2015, 02:13:55 am
Apparently the cold weather up north has shut down this thread for the most part.  Well, here north of the Equator and south of the Canal we've had good riding weather.  Today, however, all I did was check oil as "Pico y Placa" means I couldn't run the bike between 7:00 a.m. and 7:00 p.m..  No, don't ask my opinion of socialism.  I try to avoid that kind of vocabulary.
On the other hand, yesterday I did get a chance to clean up some of the grime from last weeks long trip.  Not much, but some.  The bad news is, somewhere along the way I picked up some type of oil, probably from the areas where they were repairing road - and it was raining.  Nasty stuff all over the place, but worst of all is the baked on junk on the exhaust pipe. What would take THAT off?  Carb cleaner won't even touch it, although it cleans other parts of the bike just fine.
Paul
heloego
  • USA '12 C5, '06 ElectraX
Reply #6069 on: November 27, 2015, 09:34:37 pm
Fine steel wool and some elbow grease did it for me.  :)
'12 C5 Classic
Carlsberg Wordsworth
Reply #6070 on: November 27, 2015, 10:11:45 pm
Tested new ramp :)
AmBraCol
Reply #6071 on: November 28, 2015, 01:21:43 pm
Hmmm.... will have to see if I can find any.  Steel wool here tends to be a bit coarse. That didn't scratch up the chrome?
Paul
Reply #6072 on: November 28, 2015, 01:38:28 pm
           How do you avoid taking the shine off the chrome with steel wool? Especially removing something like road tar as AmBraCol says. (Unless that's your goal as it is mine).
Reply #6073 on: November 28, 2015, 01:40:53 pm
0000 steel wool is very fine.  It's what I was taught to use to polish rusty chrome bumpers.  Works even better if you use it with glass cleaner.
heloego
Reply #6074 on: November 28, 2015, 10:52:06 pm
+1.
My shine was just fine after using the 0000.
Thanks for mentioning the glass cleaner, Scottie!  ;D
'12 C5 Classic
