Author Topic: What did you do to your Royal Enfield today?  (Read 1847021 times)
0 Members and 13 Guests are viewing this topic.
Catbird
Reply #3315 on: August 30, 2013, 06:15:08 pm
I always hard wire these Battery Tender connections directly to my motorcycle batteries.  I will be installing the one for my new RE Military C5 this afternoon.
1972 Honda CB350 twin - sold
1976 Honda GL1000 Goldwing - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2013 Royal Enfield C5 Military
2014 Honda CTX700N DCT
2014 Honda CB1100
Reply #3316 on: August 30, 2013, 06:37:32 pm
Getting the return springs off and on is a total PITA!
Another drum brake hint--To get the springs off and on easily, just rotate the shoes up to a vertical position and lift the shoes and springs out as a unit. Put them back in by reassembling the springs to the shoes outside the drum, slip them back down over the pin and cam vertically and rotate the shoes back into the drum.
Don't forget a dab of grease on the cam and pin!
Reply #3317 on: August 30, 2013, 06:45:24 pm
I always hard wire these Battery Tender connections directly to my motorcycle batteries.~
 +1 and ditto.
 I routed mine to put the connecter inside the left hand tool box.
 Beside keeping the connector secure and protected, the tool box lid being open is a visual reminder for folks like me to disconnect the battery tender before take off.  :o
D the D
Reply #3318 on: August 30, 2013, 06:57:01 pm
+1 and ditto.
+1
1975 XLCH
Catbird
Reply #3319 on: August 30, 2013, 11:59:26 pm
...I routed mine to put the connecter inside the left hand tool box...
Nice idea; I like it!
After considering my options, I think I'll zip tie mine under my solo seat and leave the free end accessible for a female cigarette lighter connection.  At some point, I will probably want/need to recharge my cell phone, GPS, etc.
2011 Vespa GTS 300
2014 Honda CB1100
D the D
Reply #3320 on: August 31, 2013, 12:36:41 am
You can get lighter sockets and USB charger attachments, GPS chargers or just plain plugs to put on other things 12v for accessories.
I put a 4 fuse block in my left tool box and ran the charger attachment through a 5 amp fuse.
1975 XLCH
JVS
  • I love chicken
Reply #3321 on: August 31, 2013, 02:18:53 am
Thanks Bare! I will note this down somewhere.  :D
crush02342002
Reply #3322 on: August 31, 2013, 03:57:21 am
burned a hole all the way through my alpine stars gp air jacket I just bought (never worn) on the exhaust of my c5. So I guess I gave my exhaust a nice black char coating....I fail...lol
Graylic
Reply #3323 on: August 31, 2013, 04:00:31 am
Tentatively diagnosed a rattle as a broken retaining clip on the heat shield.  I can't be positive though as I have not taken it apart yet, and don't really want to as the screws have yet to loosen up on me @~1900 miles.  maybe tomorrow.
1990 Suzuki DR250
2013 Royal Enfield G5
Reply #3324 on: August 31, 2013, 04:17:41 am
Went out to a little 1/4 mile long road with nothing on it and practiced my drag race launching.  1st attempt I missed 3rd gear.  But my 2nd launch was solid and I ran it all the way thru 3rd gear at about 70mph!  It felt real good, can't wait to line it up on the track Wednesday night!   ;D
heloego
  • USA '12 C5, '06 ElectraX
Reply #3325 on: August 31, 2013, 05:16:13 am
Installed my new windshield.
'12 C5 Classic
Reply #3326 on: August 31, 2013, 10:28:13 am
Graylic - go for a spin!  Before your exhaust gets too hot, briefly put pressure on the forward skinny end of the shield with your boot.  You'll feel it and hear the difference in the noise if that clip is broken...
Royalista
  • phaneropter
Reply #3327 on: August 31, 2013, 10:12:27 pm
Adress that issue forthwith as the shield may start to crack.
See my reply in the thread "Chrome outer cover of stock EFI silencer" of august 25. There's some pictures too of the problem.
Save that shield!  ;D
moriunt omnes pauci vivunt
Catbird
Reply #3328 on: September 01, 2013, 12:08:35 am
1. I went out for a ride to test the "Laminar Lip" attached to my new windshield, to see if it reduced/redirected the amount of wind from my neck area to over my helmet after making some adjustments.
I'm pleased with the results, but I still plan on perfecting the arrangement by adjusting the overall windshield's angle.
2. I opened the headlight and removed the jumper wires as described in this video...
http://www.youtube.com/watch?v=UhQUNMKRix4
2011 Vespa GTS 300
2014 Honda CB1100
Reply #3329 on: September 01, 2013, 03:31:38 am
Replaced the kicker return spring.
New on the right and old on the left.
Broken piece set in position. Note difference of bends between old spring and replacement.
« Last Edit: September 01, 2013, 07:39:16 am by Ice »
