2009 Military
26 Guests, 3 Users
safeer1980, dopeshaw, gizzo
February 10, 2016, 12:43:20 am
Author Topic: What did you do to your Royal Enfield today?  (Read 306402 times)
Royalista
  • phaneropter
« Reply #3225 on: August 11, 2013, 05:27:30 pm »
A better picture.
The pocket has in- and outer velcro. It can be attached to an item or wrapped around fe strap of a backpack/camelpack or in this case the bar.
moriunt omnes pauci vivunt
Graylic
« Reply #3226 on: August 12, 2013, 09:50:41 am »
This last weekend, I adjusted the chain on both my G5, and my old DR250s.  Both have snail cams, but the DR is a 15 minute job with only one nut to loosen and tighten, while the G5 took over an hour, and moving each adjuster one notch resulted in a slightly misadjusted rear wheel.  I love snail cams when they are designed right, and I would have no problem with the ones on the enfield if the only issue was that the cams read different settings. It is the complexity of the adjustment process, and the difficulty of getting everything back together just right that bugs me.  oh well I am sure it will get easier as I get more used to the process.
On a positive note, the enfield has been beating out my DR in fuel economy (RE 65-72, DR 60-65), and the RE is much more comfortable, and actually enjoyable to sit on for more than 5 min.
1990 Suzuki DR250
2013 Royal Enfield G5
heloego
« Reply #3227 on: August 12, 2013, 10:42:51 am »
Just broke 900 miles on the clock this morning. Since my street will be re-paved over the next two days , a perfect time to do an early oil change, and clean and polish. She's really smoothed out and I'm getting the hang of using the bi starter to kick start her.  :)
Royalista
  • phaneropter
« Reply #3228 on: August 12, 2013, 05:27:03 pm »
Hi, just wondering how cold it is that you have to use the bi starter. We had a (too) long cold winter and I had only to use it a couple of times with temps in the 20's Fahrenheit.
Catbird
« Reply #3229 on: August 12, 2013, 06:44:22 pm »
My NATIONAL CYCLE Deflector Screen DX was delivered late this afternoon.  I am in the process of installing it this evening but will probably do the final placement tomorrow when I have more light.
I'm pleasantly surprised at how small it is; sometimes it's hard to tell by the published pictures till you hold the actual windscreen up to the bike.
1972 Honda CB350 twin - sold
1976 Honda GL1000 Goldwing - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2013 Royal Enfield C5 Military
2014 Honda CTX700N DCT
2014 Honda CB1100
wildbill
« Reply #3230 on: August 13, 2013, 01:36:07 am »
you'll be happy with that- just fitted my old one to the bike today-same model
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
Graylic
« Reply #3231 on: August 13, 2013, 09:05:58 am »
Actually happened yesterday, but I got my new tires! 110/90-19 shinko 705's front and rear.  only a few miles on them, but the bike is already feeling better in the corners. Nice aggressive look too :D
« Last Edit: August 13, 2013, 10:37:21 pm by Graylic »
1990 Suzuki DR250
gremlin
« Reply #3232 on: August 13, 2013, 12:11:48 pm »
.....I got my new tires! 110/90-19 shinko 705's front and rear.......
They look good !
1996 Trophy 1200
2011 RE B5
« Reply #3233 on: August 13, 2013, 01:53:45 pm »
+1    The 705s are great tires!
Graylic
« Reply #3234 on: August 13, 2013, 10:39:13 pm »
correction: the 705's are 110/80 not 110/90.  The front just barley fits in the fender, but they handle nice.
1990 Suzuki DR250
Royal Stargazer
« Reply #3235 on: August 13, 2013, 11:05:02 pm »
Put 300 miles on the clock today running between Minneapolis and St. Paul. Time for that first oil change!
I hear there will be gobs of metal shavings and a smoother engine on the other side. Something to look forward to!
2012 Royal Enfield C5, royal maroon
1988 Jaguar XJS, nimbus white
gremlin
« Reply #3236 on: August 14, 2013, 07:08:52 am »
........Time for that first oil change!........
If you do it yourself, remember to rock the bike side-to-side or you won't get but half of the old oil out.
1996 Trophy 1200
2011 RE B5
gtdohc
« Reply #3237 on: August 14, 2013, 08:55:38 am »
Changed the spark plug and spark plug cap with NGK brand, what a surprise to me, no more cutoff at idle, no more back firing, no more abrupt throttle, no more cursing when all that happen, can't be more happy with only $14 spend.   ;D ;D
« Last Edit: August 14, 2013, 09:06:36 am by gtdohc »
Ducati Diavel 748, Triumph Speed Triple Bonnie, Kawi ZRX1100 Z750S KZ650, Honda GL1800 Trike, CB1000 CB350G CB450K, Can-Am Spyder RS, BMW R1100S, Royal Enfield G5 Deluxe B5, Harley FXDLI Sportster.
Sectorsteve
« Reply #3238 on: August 14, 2013, 05:25:27 pm »
oil/filter change cleaned, pulled wheels off in motorcycle workshop carpark to install new tyres...installed the new steel speedo gear on front wheel, raised the muffler a bit.
Catbird
« Reply #3239 on: August 14, 2013, 06:02:52 pm »
Just a little trial and error --
I kept getting the rubber sole of my right riding boot too close to the exhaust pipe when stepping on the rear brake pedal.
I decided to try adjusting the brake rod adjusting nut a couple of turns (clockwise) to see if that helps.  I felt absolutely no brake drag when turning the wheel while in neutral and on the center stand.
I may need to repeat after I check the results.
2011 Vespa GTS 300
2014 Honda CB1100
