Author Topic: What did you do to your Royal Enfield today?  (Read 1837183 times)
0 Members and 10 Guests are viewing this topic.
gashousegorilla
Reply #2805 on: April 03, 2013, 11:56:38 pm
   I had the same thought process as you Scott..... And wen't though it.  Do yourself a favor and go for the impact wrench. You can try the breaker bar to take it off first.... you may get lucky and it's easy. I tried and it wasn't.... So I quickly said screw it.  But I have an impact wrench . If you go for the impact wrench, remember you will need a 1/2 by 3/4 socket adapter for the big arse socket..... need it for the breaker bar too.
  I would leave the bike on the center stand.  Drain some oil out from the plug..... just till you don't see oil in the window. Then put a pan under the right side cover.  Your not gonna get that much oil coming out. If you MUST use the breaker bar..... A nice piece of 2x4 cut into a wedge, door stop style behind the rear wheel, should keep the bike from moving on you too much....     Then I would put the drive sprocket back on with your bar and NOT the impact wrench.
Reply #2806 on: April 04, 2013, 12:02:49 am
I've already got the 1/2 to 3/4 adapter, I neede it for my breaker bar.  Sounds like a good plan, I'll get the gun and if I don't need it I take it back unopened when I'm done.  If I need it, no delay :)
And just thinking, a small piece of wood jambed between the sprocket and chain should hold it in place just fine and not hurt anything.
« Last Edit: April 04, 2013, 12:04:56 am by Ducati Scotty »
gashousegorilla
Reply #2807 on: April 04, 2013, 12:13:25 am
    Yeah, that's a good idea too !  But if you go with the gun, you won't need the wood or the wedge. And be able to use it for all kinds of useful stuff on the bike and Car....... You know, then bring it back!  ;D
gremlin
Reply #2808 on: April 04, 2013, 01:30:22 am
What with the thermometer reaching into the middle 40's this week ......  I gave up on waiting for the AGM to self install -and- stuffed that puppy in there.
Now, I just gotta figure out how to convince this ACE air canister to install itself......
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Singh_Chicago
Reply #2809 on: April 04, 2013, 03:36:59 am
How is ur $52 battery working so far Gremlin, I havestock battery since last 3 years and plan to change soon.
GreenMachine
Reply #2810 on: April 04, 2013, 04:11:38 pm
Installed the "over wintered" battery. Wiped off a bit of the dried underneath grime, polished up the wheels and fired up the machine. Took it for a easy 20 minute ride and GreenMachine ran perfectly..You have to love this bike, she handles so easy and sounds so sweet..Since I was on a roll I decided to install the battery in the yamaha 1100  and took that out for a 30 minute jaunt.  Leaving in a hour to take it to the dealer and get the newly arrived Metzeler tires installed, state inspection and whatever else I can think of.....I even found time to fire up the wife's hyosung and took that out to loosen it up...Everything is running as should be ,so my winter storage was successful again .Rode 3 bikes in a hour n half and the enfield is my favorite..GM
Oh Magoo you done it again
Reply #2811 on: April 04, 2013, 06:29:00 pm
I just cranked down the rear brake adjuster nut to keep things from rotating. I got the nut loose with the 3/4" breaker bar in the kit, and slipped an old fork tube over the breaker bar for a bit more leverage. Came right off with that combo.
Reply #2812 on: April 04, 2013, 06:43:32 pm
Thanks for the info Bare.  Good to know it should come loose with resonable force, and nice trick with the adjuster!  I think Singh had trouble with his and eventually used a punch and hammer on one of the points of the nut.
My mechanic just texted me, front wheel is ready :)  I picked up an electric impact gun this morning just in case.  Hopefully I'll get to it all tonight.
GSS
Reply #2813 on: April 04, 2013, 07:12:07 pm
Scott,
Mine came off real easy.  Right foot on the rear brake to keep things from spinning, and a 2' long breaker bar on the Harbor freight 46mm socket.  Don't forget to straighten out the bent lock washer first!
GSS
2019 Himalayan Snow
Previous REs:
gremlin
Reply #2814 on: April 04, 2013, 07:37:03 pm
fit like a glove, it's all good !
The battery is all black, and, in my B5 it would look better without the metal cover if I had a couple leather straps to hold it in place.
As it is, I reassembled with the stock rubber straps and the metal box (for now..)
« Last Edit: April 04, 2013, 07:42:34 pm by gremlin »
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Reply #2815 on: April 04, 2013, 07:38:08 pm
Scott,
GSS
Reply #2816 on: April 05, 2013, 06:40:24 pm
Tied up with family stuff yesterday so I just put the front wheel in the garage.  Tonight I should definitely get the front wheel back on and if it's early enough I'll do the chain and front sprocket.  I'm excited to try the new BT45s and get to a few other small projects.
Reply #2817 on: April 06, 2013, 12:02:10 am
While your playing with your front wheel don't forget to lube your speedometer cable. :)
Reply #2818 on: April 06, 2013, 12:04:34 am
It's on the list along with lubing all the cables.  Thanks :)
Royalista
  • phaneropter
Reply #2819 on: April 06, 2013, 02:19:52 am
Fitting of a new rear tyre (at 11,500 miles).
Solving of a vibration problem that's been haunting for some time.
Both long bottom rear engine mounting bolts would not hold properly and worked themselves loose at every ride. The odd thing was finding a metric fine bolt fitted on english thread.  ???
Solution for one was found in freshing up the thread and fitting new bolt. The other one by adding a rubber ring (of the hard kind).
I was made to believe RE had converted to metric but likely in a Shakespearian way: a midsummernight's dream, as you like it.
Any way, to be back on a smooth ride made me immune for the low twenties and the firm harsh polar wind. Once this current elation has subsided I may start a discovery slash inventory tour on bolts.  ;)
moriunt omnes pauci vivunt
