i have a 4 speed iron. it sat outside for years before i bought it but i can proudly say thanks to this forum it is getting the love it deserves. i have done the right foot conversion and spent much time gutting and cleaning and rejetting the carb, setting the valve clearance and what not. also my dad has had an enfield for quite a while and it is now my responsibility to keep his bike up to snuff also. so onto my question
my bike runs amazing, awesome low end pull out power, smooth acceleration all around. but i hear this noise that i would like to know if anyone can help me out with. i know these are shaky machines ie, turn signal buzzing and such, and i have tried to zero in on this particular noise but i cant, it is kind of a "chirp" is the best i can describe it. like a squeaky spring on an office chair, but it only comes on at about 1/4 throttle in all gears. my first suspicion was preignition but i have statically set my timing and no matter how much i retard the timing (even into poor running) the noise is still there. once i am above or below this throttle position it stops. also i tried to see if i could get it to worsen by lugging the bike a couple of times but it did nor change anything for better or for worse.
soooo i check my plugs pretty much after every ride, because im anal and paranoid and they look fine as far as mixture and as for as all the pictures i have ever seen of plugs suffering from predetonation they dont look like that either. would i see signs of predetonation on the plug before i blow a whole in my piston? should i be worried about this sound? do i just worry to much for someone my age? the answer to that last one is yes.
thanks a bunch
michael
