Stainless steel fasteners are not going to melt holes in your aluminum cases. At least, not for quite a while. The two metals in contact with each other in the presence of moisture (especially salty moisture) will produce a galvanic reaction. And, the aluminum will the be the anode. It will be the metal that corrodes. There's plenty of info on the internet about the process. Where possible, polymer washers are recommended.
