Last Fall, I stopped by a small motorcycle dealer in West Newton, PA. The owner was interested enough to come out to look at my motorcycle. He didn't have much good to say. "I guess your only reason to buy that thing was the price." I didn't argue with him. After all, the price was certainly a factor. The main reason was that I like the way it looks. Anyway, he started pointing at all the oxidation, and told me I'd never have that problem with a Triumph or a Japanese motorcycle.
I don't know if that's true, but I am definitely noticing a lot of rust. The most troubling is the rust on the various nuts. And, the worst of them are a couple of the nuts that (I guess....not being a motorcycle mechanic yet) hold the head onto the block. The two that are the closest to the spark plug are my primary concern right now.
Is there anything I can do? I'm sure it gets pretty hot there, so I don't think anything like wax or oil will stay there long. Is there some kind of heat-resistant paint I can use on them? I'm concerned that they'll become so rusted that I won't be able to remove them, and that I'll end up having to have the engine removed and worked on.
I put a 5/16 nut on the top of the stud to check the size. It wouldn't screw on. So, I'm guessing the existing nuts are metric. Is that true? Do you know what size?
This is a 2009 Bullet 500 ES. AVL
All the other rusty nuts I can probably take care of with a wire brush and some lubricant. Thank you.
