Author Topic: Post edit?  (Read 4348 times)
  • There's a last time for everything
on: December 23, 2007, 12:11:24 am
Is there a post edit? If there is where ? If no why not? Sometimes you get a better idea right after you post a bad idea.
2005E Fixed and or Replaced: ignition, fenders,chainguard,wires,carb,headlight,seat,tailight,sprockets,chain,shock springs,fork springs, exhaust system, horn,shifter,clutch arm, trafficators,crankcase vent.
VMAX
Reply #1 on: December 23, 2007, 03:52:39 am
Once you post and the "bright light" comes on w/a better idea, you can edit your post. Simply return to the original thread. Your post will appear and offer you a choice to edit. Click edit, make your addition/correction and then click save.
That should do it. At least that's what I do.  ;)
I was wrong, you click on Modify
« Last Edit: December 23, 2007, 03:54:37 am by VMAX »
Ride Safe - Check 6 - REA #9
05' RE 500 Classic Bullet ES w/Cozy Bullet
Liberator Motorcycle Ministry
Brother Rhett
Reply #2 on: December 26, 2007, 03:09:08 pm
That's what I do, too. It's easy to edit a post. The "Edit Post" button appears below the text of your post, as a small paper and pencil icon.
Reply #3 on: December 28, 2007, 08:19:34 pm
Got it, thanks a bunch.
