2006 500
February 13, 2016, 11:11:27 am
Author Topic: Post edit?  (Read 2300 times)
cyrusb
  • Kept man
Post edit?
« on: December 22, 2007, 06:11:24 pm »
Is there a post edit? If there is where ? If no why not? Sometimes you get a better idea right after you post a bad idea.
VMAX
Re: Post edit?
« Reply #1 on: December 22, 2007, 09:52:39 pm »
Once you post and the "bright light" comes on w/a better idea, you can edit your post. Simply return to the original thread. Your post will appear and offer you a choice to edit. Click edit, make your addition/correction and then click save.
That should do it. At least that's what I do.  ;)
I was wrong, you click on Modify
« Last Edit: December 22, 2007, 09:54:37 pm by VMAX »
Ride Safe - Check 6 - REA #9
05' RE 500 Classic Bullet ES w/Cozy Bullet
Liberator Motorcycle Ministry
Brother Rhett
  • Administrator
Re: Post edit?
« Reply #2 on: December 26, 2007, 09:09:08 am »
That's what I do, too. It's easy to edit a post. The "Edit Post" button appears below the text of your post, as a small paper and pencil icon.
cyrusb
  • Kept man
Re: Post edit?
« Reply #3 on: December 28, 2007, 02:19:34 pm »
Got it, thanks a bunch.
