You can loosen one of the banjo bolts on the head, where the external oil lines attach, and see if oil is coming out when it's running.
If oil comes flowing out when you loosen a banjo bolt, then the scavenge pump is working.
If not, there is also a possibility of blockage in the external oil lines or banjos. Blockage in the lines sometimes happens.
