RE WD France 2009
February 11, 2016, 05:21:31 pm
Author Topic: Slipping out of gear false neutral question  (Read 4204 times)
portisheadric
  • 2015 Forest Green B5
Re: Slipping out of gear false neutral question
« Reply #15 on: June 23, 2010, 11:17:47 am »
Transient Ischemic Attack usually occurs after discovering an unexpected price rise, in this case I think it means  Thanks In Anticipation
« Last Edit: June 23, 2010, 11:20:41 am by portisheadric »
TPS @ 0.610 volts. Useless filament Neutral light bulb replaced with a visible in sunlight T10 5050 SMD LED
singhg5
« Reply #16 on: June 23, 2010, 06:52:24 pm »
Thanks for clarifying - it is like a new language of its own, these abbreviations.
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
Chris-G5
« Reply #17 on: June 24, 2010, 07:00:38 pm »
I got it from one of the indian parts dealers on Ebay.  I somehow got two though, so if you want one, pm me.
that is the end of my pirating this thread.
Sam
Got the heel/toe shifter. It feels pretty good shifting. Going to take some getting used to before I feel totally comfortable with it.
« Last Edit: June 24, 2010, 07:03:33 pm by Chris-G5 »
REA Member 131
  • I'd rather push my Enfield than ride a Harley
« Reply #18 on: June 29, 2010, 07:00:06 pm »
Mine did this four or five times on the way home from work today. I have less than 100 miles on the clock of my G5. I think it even slipped into false neutral a couple of those times when I wasn't shifting.
I also noticed that the check engine light comes on while this is happening, then turns off when it finds a gear. Is it normal for the light to come on when this happens, or do I have deeper problems?
It's pretty annoying (and sorta dangerous) to pop out of gear in traffic. I didn't have this issue with my AVL or my previous G5.
