Author Topic: Starter Issues?...  (Read 7653 times)
rnewton75
on: June 05, 2010, 11:17:16 pm
Hi all,
A while back in November I had the Starter Relay go out (the circuit was just stuck closed) on my 2009 G5.  I finally got a chance to get it to the shop, it was covered under warranty, and I picked it up today.  When I picked it up, I was told that my battery was dead and needed to be replaced.  Since my company purchases batteries wholesale I declined the offer for the dealer to install a new one.  I hit the starter and the relay clicked, the dealer told me that the battery only had 3-4volts.  I kick started the bike and rode home (about 40 miles).  When I got home I tried the starter thinking that I had charged the battery a little on the way home.  Nothing.  The relay clicked in the same way.  I then checked the hot wire going to the starter and there is no voltage there at all when you hit the starter button and hear the relay complete the circuit.  When you put a meter on the battery itself it reads 12.25v  When the relay closes there is no current passed between the studs on the relay either.  Does this sound right to you?
Also, the relay is totally different than the factory one (see the photo below) could it be the wrong one?
Also, is the Exide battery in the photo the stock battery for this bike?  I don't remember what my factory battery looked like (which was fine when I took it in) but I remember there wasn't a name on it that I had ever heard of...
Does any of this make sense to any one?
I also spent $220 at the same time on a new chain (only 9 months old), should that have been covered under warranty?  If the battery in indeed bad should that be covered under the warranty too?
I REALLY like my dealer, I would just like a second opinion here.
still LOVE the bike,
Thanks.
Reply #1 on: June 05, 2010, 11:51:56 pm
The battery in the picture is exactly like the battery in my C5 if that helps.
rnewton75
Reply #2 on: June 05, 2010, 11:59:53 pm
Thanks r80rt,
For some reason I was thinking the battery had a black top cap.  I must have been thinking about another bike.
I would never imagine my dealer would intentially switch out battries.  I trust them completely.  They just have many bikes in their shop and I could easily see the wrong battery being grabbed off the bench.
Thanks for the response.
« Last Edit: June 06, 2010, 12:58:02 am by rnewton75 »
Reply #3 on: June 06, 2010, 01:19:43 am
Hello RNewton:
RE G5 does come with Exide battery that is in your picture.  But I have changed the battery to Yuasa YTX14 AHL BS 12 volts because Yuasa is sealed battery and better for starting.
First check that the battery fluids are within the Max and Min levels.  If low add deionised or distilled water.  Then CHARGE your battery FULLY by an electric Tender charger for a few hours.  Its voltage would read approximately 12.4 volts after its is fully charged.  Then try it again in your bike.  If it does not start, you may need to go back to dealer and show you why electric start does not work with fully charged battery.
I have posted a picture of my G5 - battery and starter relay.  It is hard to tell if your starter relay is correct type.
rnewton75
Reply #4 on: June 06, 2010, 01:43:59 am
Thanks Singhg5,
The relay in your photo is the same one I had on mine.  It was round and held in place by that rubber strap.  Could the problem be that my battery even at 12+volts doesn't have the amperage to close the relay circuit?  Especially since it's a different relay?
Thanks again.
Reply #5 on: June 06, 2010, 01:56:35 am
Thanks Singhg5,
Thanks again.
Its quite possible that your battery does not have enough juice right now.  I had Exide battery too and it needed more care and charging than Yuasa that I have now.  Batteries lose charge in a few days, if not charged.  And running for an hour or so (40 miles) may not be enough.  By eliminating one by one you will be able to nail the root cause of the problem.
Marrtyn
Reply #6 on: June 06, 2010, 05:38:33 pm
I have just "aquired" a similar problem.
On a longish run the last weakend I was giving my G5 a little bit of stick.(after about 50 miles). For some idiot reason, I then stalled the bike at a junction, but on trying to start the bike on the elec. starter, there was nothing there, apart from some "chatering", which I assumed was from the relay. I started the bike with the kicker.
Now I was thinking that, because I was hammering the bike, that the extra vibrations that I hav'nt really had before had loosend up some of those pesky connectioms, that seem to be always comming adrift on these machines.
 My battery and relay appear to be same as your ones.I hav'nt had the time as yet to sort out my problem, but I have no reason to think that the battery is "caput" -but it will be checked,as will all the other connections/relays etc.
john hut
  • John Hut
  • EFI Bulleteer
Reply #7 on: June 08, 2010, 04:04:09 pm
I have a similar problem with my 2009 Electra Deluxe (C5)
   I returned it to my dealers who diagnosed afaulty starter  solenoid
and has put an order in for one under warranty.
I,m still waiting after about two months.
  the bike had only done 1200 miles.
   What happens with the Classics (G5) with no kick start ??
               John Hut
John Electra Deluxe Efi
Chris-G5
Reply #8 on: June 08, 2010, 05:59:03 pm
               John Hut
You got the C5 and G5/E5 mixed up.  :)
REAZ
Reply #9 on: June 08, 2010, 06:32:41 pm
I'm still waiting after about two months.
John, there is a solution which would eliminate further downtime. Most Chinese scooters use the same starter solenoid which can be used as an emergency replacement part on your bike. I ran into the same problem and I had to put the bike back on the road in 24 hours, so waiting for parts was not an option. I went into the closest scooter shop and got a $15 solenoid which worked perfect. This is how it looks:
If you want something more robust and reliable, you can install an aftermarket starter solenoid. Marine engine parts are designed to deal with harsh environment, so they should perform better in the long run than the scooter solenoid.
The installation requires a bit more involvement but it is really not a big deal. I have retrofitted multiple bikes with marine engine solenoids.
You can find more pictures and instructions at www.motorcyclesalesdirect.com/RE_installation
It is good to ride
REAZ
john hut
  • John Hut
  • EFI Bulleteer
Reply #10 on: June 08, 2010, 08:25:51 pm
Thanks Chris  .Too many drinks at lunch time .got my C,s & G,s mixed up.Ill stick to Electra,s and classic,s
  Thanks REAS,   sounds like a simple enough solution,
  Got intouch with dealer again and he says he has the part in
just got to find time to take it in,,,No problem kicking over
and still using the bike.
Marrtyn
Reply #11 on: June 09, 2010, 02:51:08 pm
Just had a check thro of my G5, and confirmed that, yes, it is the starter relay/solenoid that is chattering. Spoke to WS they are going to put one in the post for me, ASAP. They will be charging it to me but will refund/credit me the cost on return of the faulty one.(still under warranty) They are now supplying a Japanese version.
Its quicker for me to do it this way than to take the bike to my dealer and wait for them to look at it and order the part etc. I would have to pay them the labour cost!! Its only 2 nuts and one push on connecter. Simple.
They did tell me there have been one or two issues with this relay.
clubman
Reply #12 on: June 10, 2010, 09:29:56 pm
Hi Marrtyn,
May I ask the cost of the Japanese relay?
Thanks.  :)
Marrtyn
Reply #13 on: June 11, 2010, 09:27:24 am
Hi Clubman
From WS direct to me total cost was £29.32.(this includes VAT at £4.37) No delivery cost.
Ordered late Wed., recieved Thurs. morning. Good service.
They also sent me a Warranty Clain form, to enable me to recieve credit for the cost.
Not sure as yet if I will be able to claim it though as I did not have my 2000 mls. service carried out by a dealer. Did it myself. But even if I cant, it still proberbly works out cheaper than paying for labour charge's that I would have to pay for said srvice.
Regards
M
UncleErnie
Reply #14 on: June 11, 2010, 02:14:13 pm
"wear items" like batteries, chains, tires, etc are never covered by warranties.
If I were you, however, I would look into what I'm doing wrong that I needed a new chain after only 9 months.
Unless you put a LOT of miles on in that time... ?
Run what ya brung
