hen when the engine heats up the thermal expansion of the materials in the head and barrel castings causes the lash gap to widen to approximately .012", give or take a few thousandths.
It "grows" its own lash clearance as it warms up.
Interesting Ace!I've never checked my motor hot so i might give it a go.I've also got a set of the full alloy types and may put those in some time and see if theirs a difference.
I always thought these motors(well BSA's and AJ's) were set at say 6 thou inlet and 8 thou ex and as they warmed up the clearance decreased to nill and the engine ran quieter when hot but our Bullets are somehow the opposite and become noisier when hot . Or have i got it somehow wrong?
Have you looked into fitting hyd lifters?As all those other makes only ever used a fraction of the return oil to lube the rockers,where the Bullets use's 100% of feed oil that goes to the rockers via the return pump.Surely there's enough left to tap into for hyd lifers??.Anyway I'm not good technically and have no idea how much oil they require,maybe more than is available.Have you looked at HD lifter oil requirements?
coinz
What the actual hot clearance will "grow" to, is dependent on how hot the engine is running. If you are producing a lot of heat into the castings, the clearance will be greater, and vice versa.
My .012" running clearance info is because the cams have ramps designed to deal with that. So, I estimate that is when the valve is actually opening when hot. It may be somewhat different than .012" in any particular engine when hot. But the design of the cams says it would be something up to .012".
Also, .012" lash is a commonly used lash setting on many of the old Brit sports cars of the day. MG, Triumph, Austin, Morris, Austin Healey, etc, all had lash settings between .012" to .015" on their pushrod engines.
Nothing very unusual about that amount of lash in a pushrod engine.
I had a Sprite with a race cam that spec'd .018" lash.
As for hydraulic lifters, our Iron Barrel models don't have sufficient oiling for it.
I personally prefer solid lifters anyway. Hydraulic lifters are heavy and have problems.
If your lash is set cold at zero, you have no worries about having too much lash clearance, and the valves will seal when cold. That's all that matters.
The sound is normal.
As Cyrusb notes, there can be worn rockers that will make more noise, and the rockers in these engines do wear rather quickly, as rockers go.
