Bartlett Enfield for Her Majesty's Thunder
May 24, 2016, 06:56:38 am
Author Topic: Compression test values  (Read 7148 times)
LJRead
« on: December 19, 2007, 04:54:54 am »
I'm trying to get a feel for what to expect with regard to the values obtained with a pressure tester.  The compression values for the Classic and AVL are 6.5:1 and 8.5:1respectively, but how would that translate if I were to place a compression testing gauge on it with a 0-300 psi range.?
Just need to record the values for future use.
Thanks
LJ
Re: Compression test values
« Reply #1 on: December 19, 2007, 06:52:06 am »
You are mixing compression RATIOS with direct compression VALUE.
Compression testers are to enable you to examine the state of the engine in relation to ring sealing, exhaust and inlet valve seating, decomp device seating etc. An 80PSI pressure applied from a dual gauge (ideally) compressor set-up with the engine set exactly on TDC (top dead centre) on the firing stroke (Ie. both valves closed) should show a small leakage. Now depending if air can be heard from exhaust/silencer then that'd signify a leaking exhaust valve etc.
The spin over type gauge that just gets shoved into the spark plug hole while the engine gets turned over is less useful but will show ring leakage especially if the figure goes up when some oil is poured into the spark plug hole (effectively helping to seal rings etc)
Compression RATIO is a value given to an engine on how much the piston compresses the air space above the piston. Very basic explanations of it all, but you get the drift???
dogbone
« Reply #2 on: December 19, 2007, 08:36:45 am »
I got 120 psi with the stock 6.5:1 piston.
99 Enfield Bullet 535
hutch
  • Til death do us part
« Reply #3 on: December 19, 2007, 09:20:11 am »
I  was going to say that with most gasoline motor(carsand bikes) that don't have hi compression pistons, the normal figure is usualy around 120psi. That seems to be the norm in my experience. Milled heads, high compression pistons will up that figure. Diesels are another story in HIGH compression. Once single cylinder motors gets down around 80psi it is rebuild time. On a multi cylinder motor the compression shoud not vary more than 5-10psi between cylinders.    Hutch
LJRead
« Reply #4 on: December 19, 2007, 12:35:29 pm »
Thanks guys,  this helps and is what I needed to know.  I may be able to rig up a two gauge system if it becomes necessary, but mainly I want to know when the engine starts to get worn.
All the best!
LJ
« Reply #5 on: December 19, 2007, 03:25:52 pm »
If you are running the one in your Avatar (you wish!!!) it'd have been worn at about 1905.  ;D
LJRead
« Reply #6 on: December 20, 2007, 09:32:05 am »
Hey, watch out - that "Avatar" is a Royal Enfield Forecar, and since R E made it you can bet that the compression values wouldn't change for a hundred and two years.  It is well known that things never change with R. E. ;)
VMAX
« Reply #7 on: December 20, 2007, 01:19:49 pm »
Yep, "Untouched by technology" says it all!  :D
Ride Safe - Check 6 - REA #9
05' RE 500 Classic Bullet ES w/Cozy Bullet
Liberator Motorcycle Ministry
« Reply #8 on: December 22, 2007, 05:06:57 pm »
There is a direct connection between compression ratios and the pressure thats read with a "gauge in the plug hole". Why wouldn't there be? Low ratio, low ultimate reading, High ratio, high reading. If this were not true how could a 18:1 diesel have 400lbs of compression? According to published tables,a healthy 6.5:1 should have110lbs,  7:1-120  7.5:1-130  8:1-140 and so on. Always remember the throttle is to be wide open, as it varies the inlet air and therefore the compression. Also the speed at which you spin the engine should be spirited, as say the idle speed. This gives a truer reading of actual running, and shortens the time of leaking, the condition that would exist if the motor was really running.
LJRead
« Reply #9 on: December 22, 2007, 07:20:54 pm »
Yeah, of course if you compress 8.5 volumes of air space into one volume, it has a direct effect of pounds of pressure produced.  In a site on compression testing in cars the value for an average car was about 140.  I would expect about that for the AVL, or maybe slightly less.  Surprised at the high compression ratio you mention for some diesels.  Didn't realize they got up that high.
I paid a few bucks for a used compression tester, figuring that compression is a useful thing to keep track of.  Sort of like a doctor measuring blood pressure, or better his pretty nurse (higher values!).  But I guess high blood pressure in humans is a bit like very low pressure in bikes - shall we say symptomatic.   :(
SRL790
  • 1954 350
« Reply #10 on: December 23, 2007, 01:47:31 pm »
Compression ratio is the relationship between the "swept volume" (ie bore area x stroke) and what is often termed the "squish volume" (which is the volume left in the top of the cylinder when the piston is at top dead center).
compresssion ratio = squish/(squish + swept)
Domed pistons and skimmed heads reduce the volume of squish and therefore raise the compression ratio.
Compression pressure should be equal to air inlet pressure x compression ratio (+/-gains/losses).
ie. for an engine running at atmospheric pressure (14.7 PSIA) and a compression ratio of say 7.5:1 you should read 14.7 x 7.5 = 110.25 PSIG (+/-).
Of course this is all subject to valve timing, pulsing in the inlet, friction, altitude and many other factors but that's the basics.
Getting a good baseline reading is probably a good idea and may be useful for troubleshooting in the future.  Trouble is to get a good reading the engine should be at normal operating temperature, but when you're troubleshooting it's generally because the thing ain't running. >:(
Andy Wiltshire
LJRead
« Reply #11 on: December 26, 2007, 12:59:42 am »
Good point about obtaining baseline data.  I can do it with a warm engine and a cold one, so if it isn't running when I need to trouble shoot, I'll have both values.  I guess Hutch and  others aren't far wrong with values of around 120 psi for an 8.5:1 ratio.
When I finally get to doing the baseline, I'll post the results.
Thanks,
LJ
Sam
  • Uralist & now, Bulleteer!
« Reply #12 on: December 27, 2007, 08:42:54 am »
for most of you it's not an issue, but I live at about 5500ft so my normal cold-cranking pressure is about 95 psi. As a good rule of thumb, figure air density will drop about 3% per thousand feet of elevation.
Foggy_Auggie
« Reply #13 on: December 27, 2007, 03:25:35 pm »
A compression "leak down" test is the most accurate way to determine rings, piston, valves and cylinder wall condition.
It requires specific test tools and an air compressor.  Air pressure of a known value leaking down at a timed rate to "0" pressure.  And the values have to be supplied by the manufacturer.
Maybe the Enfield dealers would have the data tables for this.  And the equipment.
Regards, Foggy
Fortiter Et Fideliter
« Reply #14 on: December 27, 2007, 03:28:58 pm »
Wow, I never considered that. So when you come down to sea level it must be like adding a supercharger.
