Gnarly
April 29, 2016, 11:03:40 am
Author Topic: Tanks and Petcocks Question  (Read 927 times)
The Garbone
  • Shade Tree
  • User Complaints: 22
« on: April 19, 2010, 09:33:35 am »
Well,  pulled the petcock off my Craigslist tank to see if I can order a new one with a reserve function to replace it.    Using my calipers it measure .5 inches across and does indeed look like an original Indian petcock as listed here..
http://cgi.ebay.com/ebaymotors/Indian-Motorcycle-Petcock-2-Chief-Scout-and-Four_W0QQcmdZViewItemQQhashZitem1e5b796ed7QQitemZ130383703767QQptZMotorcyclesQ5fPartsQ5fAccessories
I guess I will have to take it to hardware store to verify the thread count but is it safe to assume its 3/8 NTP?
edited for title???
« Last Edit: April 19, 2010, 10:14:41 am by The Garbone »
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
The Garbone
  • Shade Tree
Re: Tanks and Petcocks Question
« Reply #1 on: April 19, 2010, 11:22:16 am »
The answer is 1/4" pipe.....Ehhh..  Makes you wonder..  Its quite a bodge.
I am thinking about grinding the thing smooth and getting an 3/8NTP adapter plate.  The question is weather rivets with a lot of sealer would work good or should I opt for self tap screws and sealer?
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
« Reply #2 on: July 29, 2010, 05:18:48 am »
 J-B Weld will keep the adapter plate on and it is completely fuel proof when cured.
 The float bowl on my military is coated inside and out to seal several pores in the casting.
REA #136
