my 05 Bullet
May 01, 2016, 08:26:15 pm
Author Topic: Air/Fuel Ratio Monitors  (Read 631 times)
Chasfield
« on: April 15, 2010, 11:21:19 am »
I was just looking around the K & N web site. They sell these neat Air/Fuel ratio meters. You can analyse your air/fuel mixture settings over all load/throttle settings.
http://www.knfilters.com/airfuelmonitors.htm
I think one of those would take the uncertaintly out of setting up your carb.
2001 500 Bullet Deluxe
dogbone
Re: Air/Fuel Ratio Monitors
« Reply #1 on: April 15, 2010, 12:07:08 pm »
I have always gone by plug color and throttle response.
an oxygen sensor would have to be welded into the headpipe
99 Enfield Bullet 535
Chasfield
« Reply #2 on: April 15, 2010, 12:37:15 pm »
Hmm, that would be awkward for a permanent install. I guess you could fit a sensor to an old head pipe and put that on the bike as required for carb set-up.
I couldn't see a price at K&N but 170 USD was mentioned here:
http://www.buckeyetriumphs.org/technical/Carbs/AFMonitor/AFMonitor.htm
Which also gives some interesting technical information, including details of a cheapo, home brewed version.
« Last Edit: April 15, 2010, 12:43:22 pm by Chasfield »
rideOn
  • And on the eighth day, God said...."Let's Ride."
« Reply #3 on: April 15, 2010, 12:43:28 pm »
the old skool color tune works on my n-line 4. get all four chambers the same color and then sync. less tweaking=more riding.
'82 gs850gl
'08 v-star 650 classic
