February 07, 2016, 04:06:36 pm
Author Topic: clutch lever replacement  (Read 1709 times)
jonapplegate
« on: December 10, 2007, 12:17:03 am »
 I have to replace my clutch handle. Neighbor backed into my bike and just kept backing up. Amazingly the only damage was a severely bent footrest and bent clutch lever. Any sage advice for me about changing the lever out? Thanks.
Leonard
  • I loved this bike!!
Re: clutch lever replacement
« Reply #1 on: December 10, 2007, 06:24:30 am »
Get the cable as slack as possible by adjusting at both ends and it will be a piece of cake.  It would be a good time to check and lube the cable if you haven't done that recently.  I suspect the lever will cost more than you think.
2009 Triumph Bonneville T100
http://www.romeoriders.com
RagMan
  • Bulleteer, Uralist &
« Reply #2 on: December 10, 2007, 11:31:27 am »
Also, beat the neighbor with the broken handle. :)
aka Indiana Bulleteer.
Jefferson County, WA
