Hi everyone , I'm a new owner of a 2006 Electra which was purchased new in 2009. I have just passed 1000 miles . I have a problem with the electric start . It seems that when I try to start the starter motor turns over but will only occasionally turn the engine over . Sometimes when it does turn the engine over it will do so for a second or two and then just back to the whirring of the starter motor . I just picked it up from the dealer and they said that they serviced the sprag clutch.I also had the starter upgrade to prevent backfiring done previously . I can kick start but would like everything working properly. If this problem has been discussed previously please point me in the right direction , otherwise your advice and suggestions would be appreciated . Thanks
I have, and have had, the same exact symptoms since almost day one. I have had the primary cover off three times, convinced that the sprag fragged, and three times found that the sprag is in one piece, no debris in the primary case, and refilled with one liter, 20-50 and green, updated TCI box installed.
Funny thing is, with the decompressor engaged, it will happily spin the motor all the live long day. When under compression however, it will disengage and whine. Also, when the engine is hot, it will sometimes, (and only occasionally), start the motor on its own, but NEVER when the engine is cold.
I never liked it when new and rely on the kick start always. So, I havent yet disassembled the primary case and probably won't until it absolutely needs to be, so I live with it.
I also do not know what the dealer meant by "servicing" the sprag. It is not a device that can be adjusted, only lubricated, which applys to everything within the case.
