Some of my worst carb problems concern the electric choke. Not because it's a problem. I have NEVER had a failure. It's because people don't understand how they work and then "fix" the choke instead of the actual problem. That black choke housing contains a wax medium on top of a plunger. When cold the medium contracts. This lifts the plunger off a jet that provides extra fuel to the cold engine. As the engine warms up the medium expands to push the rubber tip of the plunger down to seal off the jet. The warming is usually electrically assisted via a simple resistance loop. Removing the assembly will simply leave holes that will let extra fuel and air into the carb. You can plug the hole off, but if you don't seal the jet it will always run rich. If you manage to seal the jet you probably won't get the bike started unless it's 80 degrees out.
