Current ride - waiting for an upgrade...
February 11, 2016, 06:00:26 pm
Author Topic: Diamond Engine Bar on G5 but voltage rectifier in the way !!  (Read 813 times)
« on: March 20, 2010, 04:00:54 pm »
I got a Diamond Engine bar (part no. Z90297) and was mounting it to my G5.  The lower part of the bar has two 'ears' sticking out that I attached to the holes in the frame.  But the upper part of the bar was hitting the rectifier.  I removed the voltage rectifier and attached the engine bar to the frame with the clamp that comes with the bar.
Then I could not put back the voltage rectifier to the frame because the bar was in the way. Went to the hardware store and bought two long M6 x 1.00 x 40 bolts and two 1/2 inch spacer tubes and improvised to attach the rectifier to the frame.  The clamp for rectifier is fixed to the frame, cannot be moved.  Checked that handle bar lock was not hitting rectifier, engine bar was not touching anything else, had to adjust clutch cable a bit and went for a short test ride.
My question is how did you mount the diamond engine bar to G5 or Electra without hitting the voltage rectifier ?  Have a look at the pictures and let me know any suggestions or advice.  Thanks in advance.
« Last Edit: March 20, 2010, 04:43:53 pm by singhg5 »
Re: Diamond Engine Bar on G5 but voltage rectifier in the way !!
« Reply #1 on: March 20, 2010, 04:05:30 pm »
Full view of diamond engine bar from the left and right side of the bike G5.
« Last Edit: March 20, 2010, 04:44:44 pm by singhg5 »
« Reply #2 on: March 20, 2010, 07:37:15 pm »
The rectifier was installed so that the wires were at the top of it. The rectifier was left loosely mounted until the engine guard was mounted and then it was tightened up. I've done several of them with no problems. Good fix on your bike tho ....
1Blackwolf1
« Reply #3 on: March 20, 2010, 09:15:01 pm »
  Excellent RE-engineering.  I swear I have to that with almost every accessory I buy for our 2 beauties.  Ain't saying we all are genius rated..just saying.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
« Reply #4 on: March 22, 2010, 04:44:21 pm »
I like your idea too. That is another way to solve the problem as it does not require extra parts and is quick.
Thanks.
