Author Topic: 32mm Mikuni flatslide  (Read 8724 times)
single
Reply #15 on: March 22, 2010, 01:55:25 pm
Probly stating the obvious here but isn't it likely that with the Mondello head and Ace piston and cams,that jetting will become closer from one bike to another,what with the parts being more consistent in machining and all?Not really asking,just thinking out loud,kinda.
Reply #16 on: March 22, 2010, 02:28:42 pm
To some degree that may be so.
But it's quite variable based on the ambient air pressure, which is dictated by the elevation above sea level.
Hog Head
Reply #17 on: March 23, 2010, 01:38:08 am
Forgot to mention elevation
300m and ambient tem is always between 25-35 C
I have a matched pair of TM-32's off a Suzuki 250 Gamma (2 stroke) and thinking of using one for the RE in conjunction with ACE Clubman cams and a HD pan/shovel 87mm piston
Head will be stock with cleaned up valve pockets and a good 3 angle valve job.
Pipe is a gutted RE unit, and conical K&N filter
Since these carbs are off a 2 stroke I suspect the jetting will be all wrong.
Any educated guesses as where to start?
Ducati Supersport S
Harley XR1200
Triumph T-120 Bonnie (Hinkley)
RE 650 Interceptor
Harley XL1200R
