Aleman
A great thing about the tm32 is that it takes the same jets that the vm series carbs do.
The tm33 does not, which is 1 reason why i decided to go with the tm32 instead of it.
The exact type of jets are:
Main jet = mikuni large hex - 4/042 (available from size #50-#720
Pilot jet= mikuni vm22/210 (available from #10-#120)
Needle jet = 389 series. (available from O-0 (leanest)- R-8 (richest)
Jet needle = 5 series
The jets that come stock on the carb are: #45 pilot, #250 main, and Q-2 needle jet, and 5FP17 jet needle.
All of these jets should be available at most local japanese motorcycle shops so we should have an easier time than with the amals where we had to order and wait for jets to be shipped to us. The mikuni differs from the amal in that they have different types of jet needles for leaner and richer applications.
I think rick had to change his jet needle to a leaner one on his stock 500. I am going to be running the one that came with the carb and see how it works out for our setups.
The Mondello head #001 is on it's way to me right now, I expect it here by Saturday and will be giving updates as I install. I'll take some pictures and will do a full writeup as I get into tuning and testing of the ace piston, mondello head and magnum cam combination. It's going to be a new adventure for me. Once all the tuning's sorted, it's off to the dyno!
Hi folks,
I'm getting ready to purchase a TM32 Mikuni Flatslide to replace my Monobloc carb (will mate up to a Mondello head in the near future). I would love to hear any comments any one would care to share about things like:
- cable end match up. Have an Amal cable in right now.
- Jetting/tuning experiences. It says it typically comes with 250 main, 45 pilot, 389q2 needle. I'm not sure if that relates to Amal jet numbers or not, but I suspect not.
- I have now idea if stock jetting is going to feed a ported head, etc. I am hoping to order some jets for tuning at the same time I order the carb.
Or any other experience or comments about the carb. I did a search and found some general comments mostly about the roundslide version or the 30mm flatslide.
Thanks a lot,
aleman
