BSA DBD34 (I think), I've never actually seen the bike run. I believe it (the carb) was ordered new from AMAL a couple of years ago for a vintage track racer, but that project hasn't been completed.
I agree about the 34mm, with the exception of poor fuel economy, it kicks ass. I blended the ports on my head to match the carb. Plus the head has been flowed and large kibblewhite valves installed. My setup seems to work very well with the Redditch cams. I tried it with the stock cams and that was disappointing! I believe Aces's clubman cams are similar to the Redditch cams.
geichal
I wouldn't pick a GP carb for street use.
It might be good for vintage racing, or look good on a bike in a museum, but it's not the best choice for a street machine.
A Mikuni flat-slide carb is a much better performing all-around carb.
The Clubman Cams are somewhat similar to the Redditch cam timing, with a bit of difference, most notably the5-degree later intake closing timing of the Clubman Cam timing, and the later exhaust opening timing too.
The Redditch cams are nice, though, and give suitably more spirited results when paired with a good-flowing intake system..
