Author Topic: Ruined engine sprocket??  (Read 6982 times)
Lahti35
  • Currently Enfield-less!
  • The Department of Redundancy Deptartment.
on: February 22, 2010, 02:00:55 pm
Doing a conversion to KS only and took my engine sprocket down to get it machined. Well i got it back today and i must say it looks like my sister could have done it better and she's never touched a lathe :o See picture!
They ground the starter gear off but went too deep and put a 3/16 deep gash 1/2 way around the part that goes on the shaft. Then when they tried to clean it up on the lathe it must have been crooked because part of the machined rim is beveled and part is not ??? All i can say is good thing theres no charge!
The teeth are fine, as is the center that fits over the splined shaft. While i would have liked to seen more care used in removing the starter gear is this still servicable? Were these balanced... i just don't want to trash anything by using if its going to create problems.
'03 Ex-Electric start 500....gone but not forgotten...
I'm a fuel injected suicide machine. I am the rocker, I am the roller, I am the out-of-controller!
1Blackwolf1
Reply #1 on: February 22, 2010, 02:24:12 pm
  Well you know who not to take parts to in the future.  At least it wasn't that he was fixing your jug/head.
  I probably wouldn't trust the part on my machine.  I'd see if he will reimburse you for a new sprocket..since it wasn't gouged up like that when you took it in.  But of course I realize the chances of that are slim.
  Wonder if the store sells a k/s only sprocket and if it would fit your application.  That way you wouldn't have to have the starter drive gear cut off.
  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
Lahti35
Reply #2 on: February 22, 2010, 02:27:17 pm
  Will.
Whats really scarey is that this guy builds and works on race cars!
1Blackwolf1
Reply #3 on: February 22, 2010, 02:28:55 pm
  As another option..you could have the gouge filled and turned down to an even surface.  Then I would have a little more faith in using it.  But spray metal processes are expensive, just gives you another option.
  But of course wouldn't trust that shop to do the work either, since that's what I would have done to salvage the part had I done the work originally.
« Last Edit: February 22, 2010, 02:35:34 pm by 1Blackwolf1 »
Will Morrison
2007 500 Military
2000 Victory V92SC
The garage is full.
Lahti35
Reply #4 on: February 22, 2010, 02:33:43 pm
Think i'll just get another one and start fresh....
Anybody have a used one laying around..... isn't there a guy on the board here who turns the starter gears off?
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #5 on: February 22, 2010, 02:50:16 pm
CJ Heff over on the Yahoo board has one , at least he did last year when he cut mine off for me.  I sent him my sprocket and he sent me a replacement but the replacement had slop in the fit so he was nice enough to cut my original down for me and swap back.
I don't really think  your sprocket is trashed, it looks to me that it might still be pretty well balanced.  I don't think the thinned section will have that much stress applied to it under normal use because of the way the splines are on the shaft.   Of course its been over a year since I have looked at mine so I could be recalling things wrong.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Lahti35
Reply #6 on: February 22, 2010, 02:59:07 pm
  Will.
Roger that..... i wonder if a KS only one would fit, my Bullet is a 2003..... Anybody know?
t120rbullet
Reply #7 on: February 22, 2010, 03:04:20 pm
They could have done a better job doing that but I think it would still be serviceable.
There's a lot of meat around that spline on both sides of that groove and with the crank spline fitting tightly inside of it it's not really going to go anywhere.
As far a turning that on a lathe that metal is hard. Too hard to turn.
To do that properly it needs to be ground down with a surface grinder.
Terry Crawford of Crawford Sales in S. Lyon Michigan (A RE Dealer) has a surface grinder and did one for me. When he got it done it looked and measured identical to the KS sprocket I gave him to use for a pattern. (Ex-Toolmaker)
CJay over on the Yahoo group does it with a carbide cut-off wheel mounted on a lathe. You could look him up too.
The ES sprocket has slightly smaller splines than the KS sprocket does so a new KS sprocket will be sloppy on a ES crank.
CJ
1972 FLH "Sambo"
2023 Guzzi V7 Special "BOB"
Lahti35
Reply #8 on: February 22, 2010, 03:18:51 pm
CJ
Yes that would have been too easy :'(
Well it just bugs the heck out of me too..... A buddy of mine knows the guy and his shop looked pretty clean as did some of the work i saw. So i thought why not.... know i know why not!
I'm just going to get a new one and try again, good thing its another month at least until decent riding weather is here or i'd really be pist!
Thanks for all the help gents :)
Blltrdr
  • cycle-delic music
Reply #9 on: February 22, 2010, 04:00:17 pm
Your sprocket does seem serviceable as is. If you do decide to get another look for a local shop like I did to properly remove the material on a lathe. Mine looks like a factory part when they finished. The shop owner definitely thought my project was interesting enough to do the work on the part for a very reasonable price, $20 (beer fund). Definitely bring a photo of your bike to a shop with you, people get excited if the work is for something classic. And something the owner told me that was interesting is, that yes you fry a blade to remove the material but that each blade costs him about $7 to replace.
Good luck
2003 Classic 500 5 spd
2009 HD FLHT Police 103 6 spd
Lahti35
Reply #10 on: February 22, 2010, 04:46:35 pm
I've got a few feeler out looking for a new one but i'm wondering if i should even try to remove the starter gear from the next one, doesn't seem like there would be any harm in just leaving it there....
t120rbullet
Reply #11 on: February 22, 2010, 04:55:08 pm
The ES inner primary is held on with 3 flat head screws.
The KS one has larger bosses in it and is held on with 3 studs with nuts. The gear will hit them.
So if it is converted properly to KS you will need the sprocket without the gear on it.
CJ
1972 FLH "Sambo"
Blltrdr
  • cycle-delic music
Reply #12 on: February 22, 2010, 05:50:27 pm
CJ
I used the 4spd primary cases on my 5spd when converting from ES to KS and instead of mounting the inner with the studs and tangs I used bolts and locktite. This IMHO looks better than using the 5spd cases, keeps it looking old school!
cyrusb
  • Kept man
Reply #13 on: February 22, 2010, 09:02:31 pm
I'd run it, there's a lot of metal left there. More than enough for 20 hp.  Unless there is something I can't see in the photo. Your piston will probably fail before the sprocket.
baird4444
Reply #14 on: February 23, 2010, 01:56:20 am
[/size]
What he said...  trust me; that groove isn't going to be your weakest link or your next
failure. If the looks of it bother you I'd just put the cover on and inspect it again next year. If we start looking at these things to close under a bright light we'd all be in trouble
and never get any sleep....
   just think'n outloud...  - Mike
« Last Edit: February 23, 2010, 01:58:36 am by baird4444 »
'My dear you are ugly,
 - Winston Churchill
