benifit for you ,,, dunno , for me it has worked ok , at minimal cost , and as stated above , in its last form , is applying any oil on to the chain at the rear ,
Testing: you can hear the air pulsing thru it , and by removing the clamp on the barrel can easily blow , but not suck , so I think it works?
remember , this was an idea I thought of , and people on a couple of other forums have tried , maybe , this should go into the oil tank in hot weather? , but in the cold it causes problems.
do you also know that the early twist on cap has two positions? , run and fraight , in the first position , the cap will allow air in and breath , if you continue to twist the cap , it then seals the tank for frieghting , and you will have oil coming from every orifice , when you run the bike? , as the tank is sealed
