Roaring Bull
February 13, 2016, 09:49:35 am
Author Topic: Bang for the Buck, next level  (Read 5629 times)
Re: Bang for the Buck, next level
« Reply #30 on: February 27, 2012, 03:31:36 am »
Well I was all set to get my Mikuni and other
goodies when the washing machine went belly up. :'(
500 just for the parts.Not going to put that much in it.
Of course we cant cant just replace the washer ,it has
to have the matching dryer per OCD wife.Bye Bye
Bullet money.
Now it looks like I may have to settle for the 30mm flat side
to go with Ace canister,Goldie exhaust .
Cheers,
Jr.
Not settling at all IMHO
 The 30mm flat slide is a remarkably good carb and often under appreciated IMHO.
The part I like best about it is the throat is not circular. It is oval.
The top section is 30mm while the bottom is 28.
This results in good intake charge velocity at lower revs for good cylinder fill resulting in better bottom end torque while at wider slide openings you get free breathing for more top end power.
 The transition between the two openings is seamless and smooth and throttle response is crisp.
Jr.
  • 06 Military Iron 5speed
« Reply #31 on: February 27, 2012, 05:54:13 am »
Thanks Ice,I have heard lots of good things about the
30mm.Did you mount yours directly to the
intake or do you have some sort of spacer or intake
hose/coupling .? Spring time is on the way !
Jr.
Get On Your Bikes and Ride
mustangdave
  • ACES UP
« Reply #32 on: February 27, 2012, 08:16:50 am »
just checked out CMW...they have a good deal going on for the 30mm flat side carb...just might have to pull the trigger on this one. :o
clay
« Reply #33 on: February 28, 2012, 04:19:42 am »
Check E-Bay
2005 military RE
57 Sears Allstate 250
61 Sears Allstate 250
69 Sears Allstate 250
66 Sears Allstate 175
74 honda z50
Jr.
« Reply #34 on: February 28, 2012, 05:56:30 am »
Does our host sell the  Mikuni TM -32-1 ?
I found a Mikuni 32 but it looks like i round slide.
Also didnt see the Clubman cams.
Jr.
mustangdave
  • ACES UP
« Reply #35 on: February 28, 2012, 06:20:10 am »
Check E-Bay
I'm not necessarily E-Bay friendly....been burned a few times
The Garbone
  • Shade Tree
  • User Complaints: 22
« Reply #36 on: February 28, 2012, 07:20:28 am »
Amazon works also.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
clay
« Reply #37 on: February 28, 2012, 09:13:48 am »
E-mail me at clayboyrat@yahoo.com and I will give you the link of the person I bought my 32mm flatside off of.
2005 military RE
74 honda z50
« Reply #38 on: February 28, 2012, 08:13:59 pm »
I got mine from
  http://tiny.cc/kgfwc
came with solid mount as well....
mustangdave
  • ACES UP
« Reply #39 on: February 29, 2012, 08:46:58 am »
was on Ebay...looking for mikiuni 32mm flatside carbs...got a hit on a KOSO 32mm flatside carb...spot on dead ringer for a Mikuni...anyone here know about these?
« Reply #40 on: February 29, 2012, 09:48:53 am »
From what I was able to find, it uses completely different jet numbering than Mikuni, and I have no idea what jets to get, or even if the jets we would need are available.
Do you know how to get the proper jets and re-jet this carb? Do you know if real Mikuni jets will fit in it?
Because I don't.
Hoosier Bullet
« Reply #41 on: February 29, 2012, 10:00:18 am »
Dave,
Straight to the point.
http://www.atvunlimited.net/servlet/the-35687/MIKUNI-32MM-TM-FLAT/Detail
You won't beat the price, which is why the carburetor on my Fireball came from this very link.
If you are serious about it, go ahead and also ask these guys for a 6DP17 needle, 389 series P4, P6, and P8 needle jets, along with 180, 190, 200, and 210 main jets.
Your stock throttle cable should be fine, same as the pilot jets I gave you for the VM28 mikcarb.    You might want the choke cable conversion from Sudco but that can be done later.
This is the only way to go if you have the faintest dream that you will eventually Fireball.  There isn't a Fireball out there not running this carb, far as I know.
And last thing, ask Tom about his gorgeous custom intake manifold made for this.
Justin
« Last Edit: February 29, 2012, 10:04:01 am by Hoosier Bullet »
clay
« Reply #42 on: February 29, 2012, 11:15:51 am »
OUCH! Thats 30 bux less then I paid.
2005 military RE
74 honda z50
mustangdave
  • ACES UP
« Reply #43 on: February 29, 2012, 11:24:40 am »
Tom...Justin...thanks for the info. Just doing some "research"...right now the bike is running like a dream...thanks to the VM28 swap out and re jet...no complains about performance at all.
clay
« Reply #44 on: March 05, 2012, 03:01:39 am »
Has any one done the choke cable conversion? If so whet cable did you use?
2005 military RE
74 honda z50
