MY CLASSIC 500
May 02, 2016, 06:21:05 pm
Author Topic: Lubricating cables  (Read 3195 times)
Gaffer
Lubricating cables
« on: November 29, 2007, 03:47:13 am »
How can you efficiently lubricate brake, clutch and throttle cables?
Leonard
  • I loved this bike!!
Re: Lubricating cables
« Reply #1 on: November 29, 2007, 06:47:17 am »
CMW has just what you need http://www.royalenfieldusa.com/cable-lube-p-525.html
2009 Triumph Bonneville T100
http://www.romeoriders.com
« Reply #2 on: November 29, 2007, 06:56:48 am »
From a post by Dewjantim:
To make a simple, effective cable lubing device take a couple of inches of fuel line and put a clamp on the end of it. Take the cable loose and clamp the fuel line tightly to the end of the cable.  Pour motor oil into the fuel line, being careful that the cable is pointed straight into the air. Let set overnight. The oil will drain into the cable and it will stay lubed for a long time.....Dew
I would add to Dew's technique that you can probably push the oil quickly through using a dowel as a ramrod inserted into the open end of the hose.
I still have a well-cared for JC Whitney cable lube syringe that's about 15 years old. It's a standard plastic medical syringe (I think 100cc) with a clear 4 inch hose clamped to it. A rubber stopper goes over the cable end and is inserted into the hose. A hose clamp tightens it all up. Then you just pour in oil and apply gentle pressure until it drips from the other end. (Pushing the exposed cable end in and out from the bottom end expedites the flow as it draws the oil downward).
These simple but effective lubricators cannot be found anymore. I keep thinking about finding sources and then posting do-it-yourself instructions
For the RE maintenance-obsessed, all it takes is consistently, every 5000 miles, removing the cable completely, inspecting it thoroughly, pressure lubricating it with your lubricant of choice, cleaning both exposed ends, clean mounting points and lubing lever and bracketry pivot points; also making sure that it is reinstalled properly. Then every maintenance in between (1850 miles for our REs) cleaning exposed portions and re-lubing with your lubricant of choice, then carefully inspecting for wear.  :-)
« Last Edit: November 29, 2007, 06:59:38 am by Thumper »
SRL790
  • 1954 350
« Reply #3 on: November 29, 2007, 08:27:24 pm »
I use one of these cable luber gizmos (see picture) which are available from most motorcycle parts suppliers and probably your local Honda shop for $10 or less.
CMW sells them here
I use a teflon/silicon aerosol lubricant that you just attach the little plastic tube to the gizmo and spray until it comes out the other end.  You may have to detach one end of the cable but it can be done on the bike.
Avoid using an oil based lubricant on modern teflon lined cables.  It can make the teflon swell and cause the cable to stick.
« Last Edit: November 30, 2007, 01:26:30 pm by Royal Enfield 1 »
Andy Wiltshire
JLR
« Reply #4 on: December 03, 2007, 08:54:27 pm »
Thumper Matt,
try this site. We use these syringes for dispensing things like epoxy resins and di-electric grease where i work. Don't know how much or if they will do business in small quantities, but thought I'd throw it out for ya.
www.efd-inc.com
Gaffer
« Reply #5 on: December 04, 2007, 03:46:35 am »
Thanks for all the replies - I like Dewjantim's idea (KISS), and will try that. I presume, (re the comment from SRL790)  that Electras don't have anything as hi tech as teflon lined cables, and sewing machine oil would be the best lubricant?
« Reply #6 on: December 04, 2007, 06:35:30 am »
Thumper Matt,
www.efd-inc.com
Thanks for the link. I'll check it out.
t120rbullet
« Reply #7 on: December 04, 2007, 08:25:41 am »
Myself, I'm too cheap to buy a tool to lube a cable. I stick the cable through the corner of a plastic bag, wrap a couple of twists of electrical tape around it and put a teaspoon of dry graphite in the bag and then spray enough TriFlow or WD-40 in the bag to carry the graphite down and then clip the bag up to my garage door opener until it runs all the way down and comes out the bottom. (garbage can underneath it!)
CJ
Leonard
« Reply #8 on: December 04, 2007, 04:29:44 pm »
CJ,
  If you would put another bag on the low end of the cable you could use lube again and call yourself really cheap.
Leonard
CJ
t120rbullet
« Reply #9 on: December 04, 2007, 05:02:01 pm »
CJ,
[/quote]
Good idea Leonard! :)
I wouldn't even have to poke a hole in it. That way I could reuse the bag too!
You'll have to wait till the Reunion next year to get the results though!
CJ
« Reply #10 on: December 10, 2007, 03:53:42 pm »
CJ,
Leonard
 ;D
