Indian Chief muffler on the C5
May 03, 2016, 09:01:53 pm
Author Topic: oil change on Electra  (Read 2091 times)
portisheadric
  • 2015 Forest Green B5
« on: November 27, 2007, 07:53:25 am »
I have found the easiest way to do an oil change during a service is after having replaced the old oil filter with a fresh pre-soaked one, is to pour in the fresh oil via the exhaust rocker cover.
The oil will start to fill the timing chest and then overflow into the oil tank itself .
Stop at required level and kick the bike over until fresh oil appears at the rocker.
At this point the whole lubrication system will then be fully charged with fresh oil and ready to run without any part of the main engine not having oil where it should be.
Replace rocker cover (and after a quick check of the wiring loom for chaffing etc. replace the petrol tank).
Ric
TPS @ 0.610 volts. Handful of LEDs fitted and an NGK plug and cap, otherwise standard.
Foggy_Auggie
Re: oil change on Electra
« Reply #1 on: November 27, 2007, 01:49:35 pm »
On my classic engine Sixty-5, I perform the standard oil change process but have the spark plug removed.
Keeping the spark plug grounded, I spin the engine with the electric starter a few times - but never more than about 5 seconds per interval.
After re-installing the spark plug and starting the engine, I let it idle for about 5 minutes.  Shut it down for 10 minutes and recheck the oil level.  Adjust the level to the center of the dipstick range - go ride.
Regards, Foggy
Fortiter Et Fideliter
dewjantim
« Reply #2 on: November 27, 2007, 06:35:27 pm »
I just drain mine, change filter, fill with oil, then go.......Dew.
dogbone
« Reply #3 on: November 30, 2007, 11:34:12 am »
dew's got it down !  There's always oil in the pump,and on all the moving surfacessss
For the price of 2 quarts- o- oil. Mine never gets dirty, let alone break down in viscosity .
99 Enfield Bullet 535
