Military at rest.
35 Guests, 6 Users (1 Hidden)
tracendaz, ace.cafe, oTTo, cstorckiii, gizzo
May 04, 2016, 12:31:58 pm
Author Topic: Push rod ends.  (Read 850 times)
chinoy
Push rod ends.
« on: January 21, 2010, 08:49:56 am »
The push rods are Ali with steel ends.
Are the ends screwed in or pushed in.
Is it possible to pop the ends off. Say to shorten the rods and then put them back in.
If its a screw in type do you know if its a reverse thread or a straight thread.
Somebody had some push rods which where bent they could maybe experiment.
coinzy
Re: Push rod ends.
« Reply #1 on: January 21, 2010, 03:31:16 pm »
They just push on,but you will find the alloy ends have been turned down just the tinniest smidge.
coinz
chinoy
Re: Push rod ends.
« Reply #2 on: January 25, 2010, 12:30:14 am »
Thanks
Any idea what the pre-load should be on these hydraulic tappets ?
Does the service manual give any info on how to check your rod length / pre load / lash.
Harley boys recommend around 40 Thou off pre-laod. So Im going with that with the lack of a better number.
Re: Push rod ends.
« Reply #3 on: January 25, 2010, 08:34:38 am »
Thanks
I heard a rumor that the hydraulic tappets are actually the same ones used in one of the Harley models. I don't know which model.
You might look into it.
chinoy
Re: Push rod ends.
« Reply #4 on: February 04, 2010, 01:41:35 am »
I imported the Harley lifters and cam to install on a bullet back in 2004
Whats on the UCE is identical to what I imported.  ???
