February 09, 2016, 07:12:48 pm
Author Topic: Where do you get taps and dies?  (Read 2177 times)
indian55-123
« on: January 11, 2010, 08:14:59 pm »
Does anyone know where I can get  1/4, 5/16. 3/8, 1/2X26 TPI  taps and dies? I am very confused about these English sizes. I thought I needed Whitworth but now it seems I need BSF. I really don't want to go metric, I just want to clean up threads. I've read on here that some businesses make a Whitworth size  head for nuts and bolts but the threads are metric or some other crap that will screw up your threads and I sure don't need that kind of trouble if I need to buy nuts or bolts. So what's the word on this kind of stuff? As always any help will be greatly appreciated.
     Thank you, Duane
GeorgeE
Re: Where do you get taps and dies?
« Reply #1 on: January 12, 2010, 10:32:11 am »
Here's another source
http://www.britishfasteners.com/mm5/merchant.mvc.
What model 55 do you have?
George
47 G
5? Bullet
58 Trailblazer
59Constellation
61 Hornet
64 500 Twin
64 Interceptor
2007 Electra
indian55-123
« Reply #2 on: January 12, 2010, 01:17:56 pm »
Thanks Will and George, will check these places. Forgot to mention in my first post that the bike is a '55 Tomahawk 500 Twin. I've had it over 40yr. and would like to get it going again. Engine is almost rebuilt except heads and carb. Would hope to be done by fall if money streches far enough. In the meantime cleaning and playing.
  Thanks again, Duane
1Blackwolf1
« Reply #3 on: January 12, 2010, 02:15:01 pm »
  No problem, good luck on the rebuild project.  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
GeorgeE
« Reply #4 on: January 12, 2010, 02:22:27 pm »
Hey Duane
Any pictures? I'd love to see it.
47 G
5? Bullet
58 Trailblazer
59Constellation
61 Hornet
64 500 Twin
64 Interceptor
2007 Electra
indian55-123
« Reply #5 on: January 12, 2010, 04:36:41 pm »
I'm new to this computer stuff so I don't know how to send pictures yet. Just one more thing I need to learn so I can try to keep old age away. Lots of fun. I've only locked it up once so I figure I'm doing preaty good.
   Thanks, Duane
rotorwrench
« Reply #6 on: January 13, 2010, 12:41:26 pm »
You will be looking for Britsh Standard Cycle (BSC) taps & dies. They are all 26TPI.
British Tools & Fasteners has a nice set but they aren't cheep. The ones I bought years ago weren't very expensive but they only came in a plastic bag. No fancy box that's for sure.
indian55-123
« Reply #7 on: January 13, 2010, 02:58:30 pm »
Thanks rotorwrench, I was on the B T & F site last night and found some of what I  need, then it was very late so I went to bed. Will send them an email today.
  Thanks again, Duane
morsey
« Reply #8 on: February 19, 2010, 01:07:49 pm »
www.tapdie.com
this company in the uk currently have a sale of BSC taps and dies on. even with postage to the states they might be cheaper.
rotorwrench
« Reply #9 on: February 20, 2010, 08:55:22 am »
I'm away from my resources right now but I can give you some information. All of the early twins used 5/16 studs for the cylinder & head hold down plus the odd tube nut in various lenghs depending on the year & model. The later Interceptor models were 3/8 studs. I've found many of the older models drilled & tapped for 3/8 studs as a repair or strengthening solution. Heli coils were hard to come by back then. I'll have to check some studs at my shop to be sure but they were one of the three British Standard screw thread types. British Standard Fine (BSF) in a 5/16 is 22 tpi, British Standrad Whitworth (BSW) in a 5/16 is 18 tpi, or British Standard Cycle (BSC) which as you now know are all 26 tpi. Most of the old Royal Enfield parts books give the thread size for the studs, nuts, & other screw hardware so I'll check one out when I get to the shop.
Kerby
Post Script: I checked my 1955/56 Royal Enfield 500 Twin parts book and it lists 10 each 5/16" X 4 5/16" X 22 tpi (BSF) studs for cylinder/head holdown plus the two differennt length special tube nuts  (6 ea 5/16" X 1/2" & 4 ea 5/16" X 3 1/4" shouldered nuts).
« Last Edit: February 20, 2010, 02:24:28 pm by rotorwrench »
indian55-123
« Reply #10 on: February 20, 2010, 02:49:22 pm »
Thanks Kerby, that really helps. WAY to many British threads for me to figure out what is the correct one. All the thread gauge that I have says is 22G which tells me nothing. I have ordered another gauge and looked for references to these numbers at sites that sell taps but have understood none of it. So far you're the only one to provide specific information for what I need and  I truly appreciate it.
Thank you, Duane
