I tried using 3 heavy spring from CMW on my 4 speed and it didn't work at all. But it isn't hard to find out so you might as well try it.
Here, look at this. It's the inboard side of the LH shift linkage bottom lever. It's all welded up so the only way to remove it would be to first remove that part of the frame.
Now that I know what to look for, and while the primary cover is still off, I can check if the previous owner (the mystery man who apparently had the same ideas as me) really did install the bushing kit himself. If he did, worst is that I'm out $25. (By the way, that's way too expensive for two metal bushings, small bolts, regular nuts, locknuts, and bad instructions.)
................................................................................I didn't think it was too difficult, but you will need to remove the primary to get those sealed bearings in place. If you don't have a bearing drift you can get the right set at Harbor Freight very cheaply, like $11.00 and it will save you a lot of time.........................................Cheers,Donovan
