My Bullet
May 05, 2016, 07:26:12 am
Author Topic: Proud new C500 owner.  (Read 2225 times)
chinoy
Re: Proud new C500 owner.
« Reply #15 on: December 29, 2009, 01:42:57 am »
It appears  both wires are  white. However I have not checked them with an ohm meter.  The other two wires are black and grey
If you or somebody could tell me which pin is positive and which is Ground.
It would save me a lot of grief from reversing the polarity and blowing up my ECU.
I have a simulated NB output all ready to be hooked up. (Almost any WB on the market will give you a simulated NB output.)
You can re-program the Values so the ECU is fooled into injecting more or less gas.
