Good points, ACE - especially about the lazy mixture distribution in the combustion chamber. The biggest single problem that I have found with the crap they call motor fuel in THIS country is the fact that it is NOT a product of the distillation column - but rather an azeotropic mix of paint thinners, alcohols, vaguely flammable toxic waste and tars and asphalts. None of this crud will really bond together or vaporize very well in a combustion chamber that is not of truly modern design.The fuel is OK in a new modern and wonderful high-swirl, EFI motor. In the Bullet, however, you have a phenomenon call "cracking off" in the combustion chamber due to the lazy flow of the reactible gas in the chamber. The lighter aromatics will separate from the heavier tars and asphalts and actually "re-refine" from the heat in the chamber and light off spontaneously, causing detonation. This can occur with even premium fuels in our beloved Bullets. In India the 60 octane poop they run the bikes on is a "single molecule" distillate - right out of the distillation column and it will "stay together" in the combustion chamber just fine. It will also, even after after MONTHS in the crate, run the bikes just dandy. OUR pump fuel won't do that as the lighter aromatics boil off seemingly overnight, leaving sludge to foul the carbs and eat the o-rings and seals.
Long story short on all that jazz - shop around for a fuel BLEND - not necessarily the octane - that will not detonate in your bike. My experience tells me that BP fuels are EXCELLENT - especially those with "Invigorate" in them. They return higher mileage and offer the best "feel" under the throttle hand.
