chris-bartlett Enfield Bullet 500
February 11, 2016, 09:47:01 pm
Author Topic: broken clutch cable  (Read 5557 times)
hoppyre
  • 06 Bullet Sixty-5. 09 Suzuki Tu250x
broken clutch cable
« on: November 13, 2007, 06:49:01 am »
Well, my clutch cable broke yesterday on my 06 Sixty-5 while I was test riding her after installing the electronic ignition. She only has 1450 miles on it. Have any of you had this same problem??? I have a new cable coming from my dealer, should be here today!!!     Mark
mtrude
Re: broken clutch cable
« Reply #1 on: November 13, 2007, 07:28:05 am »
Hello, no not yet, Where did it break? I always put a drop of oil on the "ball" at the  lever end, It needs to pivot in the lever and not flex back and forth. Have fun, mtrude
Eamon
  • Good golly Miss Molly
« Reply #2 on: November 13, 2007, 10:05:31 am »
Yeah, I broke on at 1350 miles or so, but it was kind of my own fault.  My bike had a slow speed fall over and the clutch lever had gotten a little bent/scraped.  The ball end was not free to rotate and there was a burr on the edge.  If I had inspected it closer, I would have noticed (and fixed) those problems before the cable broke.  Anyway, I've fixed it now (bent things back, filed burrs, lubricated).  It sure is hard trying to find a place to pull over without a clutch!
Eamon
Eamon in Seattle
2006 Bullet 500 Deluxe
http://www.sterlingloons.com
« Reply #3 on: November 13, 2007, 10:11:10 am »
The best thing you can do is to spray the ends of the cable with WD-40 on a regular basis. Cables frequetnly corrode from the inside out and this will prevent it. Just the moisture in the air is enough to cause this.
hoppyre
« Reply #4 on: November 13, 2007, 06:50:37 pm »
Mine broke at the ball end in the transmission. Took out the cable, opened the trans filler plug, and there was the ball still on the clutch release lever. I'm glad it didn't fall into the transmission.
« Reply #5 on: November 26, 2007, 11:34:14 am »
Dont these things come with a spare clutch and front brake cable in the tool box? At least thats what my owners manual says, spare tube too. I got my 2005 used with nothing. I hope the spare cables aren't needed often.
Emmet
  • Tampa Bay Piper
« Reply #6 on: December 22, 2007, 06:52:27 am »
On the way to work last night lost the throttle cable; 5K and change...Bummer. Ignominy of returning home in the bed of a pickup truck (not to mention being late for work). Ordered the "premium" throttle & clutch cables from CMW. Recently had that notorious rubber tube that holds the carburetor to the intake manifold spontaneously develop a 3" tear; at least duct tape got me home that time. Any other "weak links" I should keep a lookout for?
Oh, yeah...among other things that you should periodically check for having vibrated loose or spontaneously unscrewed themselves, check your spark plug. Mine launched itself into the next county a couple of weeks back; at least I was within sight of my street (albeit downhill) when that happened.
Leonard
  • I loved this bike!!
« Reply #7 on: December 22, 2007, 02:01:10 pm »
Ordered the "premium" throttle & clutch cables from CMW. Any other "weak links" I should keep a lookout for?
Emmet,
  Assuming the throttle cable broke at the twist grip, when you install the new one you will see why.  The nylon/plastic housing the cable fits into puts it into a bind and instead of rotating in the housing it flexes the cable and eventually wears it out.   You can rework it with a small rat tail file and a pocket knife.
  you will have about the same thing with the clutch cable, you will have to rework the clutch actuating lever to get the premium cable to fit and rotate properly.  A dremel tool will make it easy.  Just as precaution I would check the clutch cable now, maybe you can catch it before it breaks too.
Been There,
Leonard
2009 Triumph Bonneville T100
http://www.romeoriders.com
Eamon
« Reply #8 on: December 22, 2007, 03:32:46 pm »
Yeah, my manual said the same thing, but I had no cables in my toolbox (although it did have the toolkit and spare tube).  Of course, the dealer I originally bought from (I don't think they are a dealer anymore) took months to even get me the manual!
Eamon
Eamon in Seattle
« Reply #9 on: December 22, 2007, 04:42:06 pm »
You have to wonder, in this century should this be happening? I don't know about you guys, but Most of  the other bikes I have owned went their whole lives without these failures.
Emmet
  • Tampa Bay Piper
« Reply #10 on: December 22, 2007, 05:35:34 pm »
Yes; I'm replacing them as a pair. They are both of the same "vintage" (2006!? 5600 miles!?)
The thought's crossed my mind on more than one occasion.
In 9 months and 5400 miles:
Rode it home on "Reserve". Apparently it had never been ridden on reserve before; coughed, sputtered, and stalled all the way home. Rinsed the tank, replaced the fuel line, added in-line fuel filter, stripped and cleaned carburetor. Now I ride it on reserve once a week, just in case (actually used reserve as it was intended once, and it worked as intended, too).
On start-up engine made the most ungodly clattering noise I've ever heard an engine make and survive. Adjusted exhaust tappet A LOT. I suspect it's exhaust valve seat slipped, something I've never heard of except with Royal Enfields; what can only be described as shoddy manufacturing. Now I always leave it on the compression stroke when parked.
Coughed, sputtered, backfired, wheezed, stalled; just made it to work fiddling constantly with the choke and throttle. Rubber manifold had failed, ubiquitous to Royal Enfields. Made it home with duct tape, replaced with radiator hose and good stainless hose clamps. Piece-of-crap part; no other way to describe it.
Dead on side of road; rode home in back of truck. Despite fuel filter, something gagged one of the jets. Cleaned the carburetor and recharged the battery.
Ejected spark plug. It apparently unscrewed itself from vibration. Installed extra plug, but it had apparently discharged the increasingly feeble OEM battery. Pushed home, installed new plug (heavily torqued this time) and new battery. Ordered a capacitor.
Broke throttle cable. Rode home in back of truck again. Piece-of-crap part paired with poor engineering; no other way to describe it.
While two can be ascribed to ID-10-T errors and one to simply the fickleness of the internal-combustion-engine gods, that does seem to me like an awful lot for an essentially new machine.
« Last Edit: December 22, 2007, 06:06:51 pm by Emmet »
Leonard
« Reply #11 on: December 22, 2007, 05:50:43 pm »
  My throttle cable went at 2500 miles and the 1st clutch cable at 4000.  I had the 1st premium cable go at about 11000.  For the 2nd premium clutch cable (3rd clutch cable) I worked over the clutch actuating lever that I mentioned, hope it lasts longer.
  What century?  The last of course! circa 1955.
« Reply #12 on: December 22, 2007, 06:22:50 pm »
Hey, not to beat this to death but was there any warning?You know, they usually give some warning, gritty feel etc. Or did the end just pull off? The fella with the throttle cable failure really blows my mind, I mean it has a nothing job to do and it broke? and at low miles?   Does the factory have anything to say about this?
« Reply #13 on: December 22, 2007, 07:40:22 pm »
We have to remember that the Royal Enfield is not a "set it and forget it" motorcycle.
The last motorcycle I rode that broke cables (clutch cable) was my then new 1968 Honda CL90.  It was fun with my step-dad on the back pulling the cable so I could shift while we rode home.  Brought us together somehow...  After that it was a regular feature of the bike to lube the cables.
Emmet
  • Tampa Bay Piper
« Reply #14 on: December 22, 2007, 11:26:56 pm »
Nope. No warning at all...just riding to work, slightly twist the throttle; no response. Roll on a bit more and realize there's no resistance at all; upon inspection, the end had frayed through or pulled off at the throttle; came right out in my hand. Yes; it had been regularly lubed.
