RE WD France 2009
February 06, 2016, 09:38:01 am
Author Topic: Crankshaft balance  (Read 2212 times)
indian55-123
Crankshaft balance
« on: November 26, 2009, 01:30:15 pm »
Does anyone know of a shop near Charleston WV area or closest place to it that does crank balancing? I have a '55 Tomahawk 500 Twin that needs balancing and crank turned. I have new pistons, pins, rings and the rods are good but I can't find a shop that will do the work even close to this area  (Beckley WV.) They won't even turn a crank anymore. Everyone says if it's broke they just put in a new one. Even if I found a new one I would still need the work. So any help will be appreciated.
     Thanks, Duane
t120rbullet
Re: Crankshaft balance
« Reply #1 on: November 26, 2009, 02:00:32 pm »
     Thanks, Duane
Gary Rask of Rask Cycle in Pa. turned and balanced the crank on my Trump.
http://raskcycle.com/
It did stay true to form and will still vibrate the fillings out of you teeth.
If your getting it turned to put some oversize bearing shells in there's a good chance you won't have to balance it.
Yes, it's getting hard to find anyone that will actually work a motor anymore. Everything is strictly R&R nowadays.
CJ
« Reply #2 on: November 30, 2009, 11:51:47 am »
Maybe you can add some weight by adding roundstock to the wristpin bores. It's worked for me. Your very lucky to have the original piston weights, so you can at least get back to the original balance ballpark.
« Last Edit: November 30, 2009, 11:56:40 am by cyrusb »
