Ok, I got a solo seat and got it customized to lower it even further. My mechanic also found a way to stick a center mounted sidekick stand on my bike even though it's a 4-spd too. Feet still aren't flat but it's low enough now to be much more comfortable riding it. Still can't get it on its center stand without help but unless I want to start taking steroids I guess I'll just have to deal.
Got completely confortable pushing the bike around and am fairly comfortable with the weight now.
Thanks everyone for the great advice! So now on to my mechanical issue....
Now keep in mind I'm a total beginner with engines, and as much as I'd like to tinker with my bike I have no clue what the issue is to even begin messing with it. When I first got this bike the ES wasn't working at all, and the bike would never idol at a stop no matter how warmed up it was. I replaced fluids, the battery, and the spark plug. Found the idol screw and messed with that. It was still really cold blooded and I never could get her to idol well but the ES was working so easily that I could start it when it died at stops, so no worries. Well now that week of pleasure has passed and the ES is only making a depressing rrrreeeh rrehh sound when I try to use it. It kick starts fine, but as I said before I can't get her on the center stand and am already tip toe-ing the bike, trying to kick start it at every stop isn't an option.
So... any ideas what I can do? I either need to get her idol stronger or at the least get the ES working so that I can restart her easily. Should I try replacing the starter?
She kicks and runs fine with the choke on, taking the choke off instantly kills her. I played with the little throttle adjustment thingy above the carb but it made no difference. I then kicked her, this did not work either.
Help!
I'm having a love/hate relationship with my bike right now.
p.s Black smoke and a small bit of gasoline was pouring out of the piping that runs from the carb to the engine block. I placed some well chewed bubble gum and some electrical tape around it. The black smoke is now pouring out of the air filter box. Should I be alarmed?
p.s.s I often refer to engine parts as black thingys, metal thingys, and pipe thingys. Attaching names to these parts would be nice.
