WELL...after re-reading my posts,and all of your fine ideas,I went back and double-checked EVERYTHING...Vince hit the nail right on the head...when I pulled/cleaned/reinstalled the carb,I had it leaning outboard just a bit too much...like I said,there may have been a few beers involved...when I tilted it back as far in towards the center as it would go,that put just enough slack in the cable for it to idle down...no more wide-open throttle,no more sticking...just putt-putt-putt...whew...I knew that the slide wasn't 180 degrees out...I feel like an idiot...the bike was doing just what it was supposed to...as usual,it was the nut that connects the seat to the handlebars that had everything screwed up...sooner or later,I'll have her squared-away,and be able to ride more than wrench...thanks,Vince,you saved my sanity...and thanks to everyone else with a suggestion...you Enfield guys ROCK...Bullethead63~
