Some strange terminology here from over the pond.
A tappet to me is the rocker arm and adjuster screw ( the tapping bit )
A cam follower is what you call a lifter.
Why does phosphorous in oil not needed for hydraulic followers / lifters?
If I was a cam lobe and I looked up I would not be able to tell if I was pushing a flat base follower or a hydraulic one. Its job and appearance is the same except that the hydraulic adjuster takes up the slack. So I dont understand you comment that the phosphorous oil will not be necessary on hydraulic followers?
I'm not sure about why the hydraulic lifters don't need as much of it.
It's just something that is mentioned by the oil companies as an explanation.
Maybe it's because most of the hydraulic lifters these days are rollers.
There have been numerous examples of heavy cam and lifter wear on solid lifter classic machines, which bear out the problem associated with the new oil formulations.
There are warnings all over the internet on all the classic car websites about it.
It's a pretty well known thing now.
But there are oils which still have sufficient amounts of these additives. You can still buy older oils from previous formulations, or you can buy "off-road" oils that are formulated for vehicles that don't have catalytic converters.
And some racing oils too.
The supposed threshold is about 1000-1100ppm or more, of ZDDP and phosphorous content for the older vehicles.
