Its a Mikuni.
Yes it is, you can tell because it has Mikuni in the alluminium casting on the body.
This is a dead give away.
A lot of oil changes in the first 100 miles? your joking?
Please explain why phosphorous and zinc oil helps break in engines. I have never heard of this before. Does it assist in grinding the parts or something yet not the cams.
What are flat tappets?
Phosphorous and zinc(ZDDP) are oil additives which help resist scuffing of surfaces, particularly cams and lifters, on solid lifter valvetrains. It is not as important with hydraulic lifter valvetrains.
Since solid lifter valvetrains are not in use much anymore, and the phosphorous and ZDDP shortens the life of catalytic converters, the new API standards call for reduced phosphorous and ZDDP content in the new oil formulas.
It is particularly useful to have at least 1000ppm of ZDDP and phosphorous in the oil during break in, and it does make for reduced cam and lifter wear.
Once they are broken-in, it is less necessary, but it does help to use oil with high ZDDP and phosphorous periodically to keep some on the metal parts, especially the cams and lifters.
"Flat tappet" is just a generic name for a tappet that is not a roller type tappet or a radius-type tappet. We have flat tappets in the Bullet, of "mushroom" type, that have a wider foot than the shaft.
I didn't really call for "alot" of oil changes in the first 100 miles.
I recommended an immediate change, so that he knows what is in there, and when it was changed, and that the condition of the oil is good.
Then, again at 100 miles to drain out any swarf or bits that may have not come out in the initial change. And this does usually yield some bits coming out.
At 250 and 500, it's draining the last bit of break-in material coming off, and I think it helps, particularly since oil is cheap, and getting any bits out can help.
He doesn't "have" to do this,
It's just what I think can be helpful.
