1968 Rebuild
February 05, 2016, 04:24:42 pm
Author Topic: Anyone got a good way to set up the carb on a 500?  (Read 4131 times)
« on: November 04, 2007, 03:01:39 pm »
I have a std Bullet 500 ES Army. Just removed the plug and think the engine is running a bit rich as it's rather black after a run out. I think a bit of playing with the air bleed jet might be required (unless a change of mains etc is required over the std set-up etc?).
Any hints for how to get this right? Is it a question of just weakening the mixture (without going too far of course) by screwing the air bleed out a fraction at a time or what?
Thanks in advance for all hints, pointers and tips.
Chris
Re: Anyone got a good way to set up the carb on a 500?
« Reply #1 on: November 04, 2007, 08:53:10 pm »
The following is from my files...
"Idle by Carston"
Carston used to be active online and his experience and know how about these Bullets was extensive. A couple of years ago he started on an Enfield web page but it vanished... don't know what happened to him.
- Mike
Idle...
The idle mixture is adjusted by the pilot air screw. Clockwise rotation of the pilot air screw richens the mixture. The idling speed (rpm) of the engine is adjusted by changing the closed height of the throttle slide, using the idle speed screw. The pilot jet size controls fuel flow. Jets are stamped with a number indicating the fuel flow in a given time.
A good start is to close the pilot-air srew carefully and to re-open it 11/22 turns again. Never tighten the pilot-air screw, this will demage the carb. The 11/2 turns correspond to one pilot jet size. If you have to turn more, use the next larger/smaller pilot jet instead. Set the idle rpm to a slightly higher speed than desired later. Open the pilot air screw until rpm drop and close it until rpm drop again. Adjust to the middle of these two settings. If the engine does not respond well to throttle opening (hesitates, stutters, stalls), you need a larger pilot jet. If the spark plug fouls (decreasing rpm until the engine stalls), try a smaler pilot jet. Finally, adjust idle rpm using the idle speed screw.
RagMan
  • Bulleteer, Uralist &
« Reply #2 on: November 05, 2007, 03:57:23 am »
Thank you for that information. I need to reset the carb on mine, for when I get the ignition sorted out.
aka Indiana Bulleteer.
Jefferson County, WA
« Reply #3 on: November 05, 2007, 12:19:03 pm »
Thanks. Glad top say that is pretty much as I remember it from other carbs but nice to have my memory confirmed!!!!!!
t120rbullet
« Reply #4 on: November 05, 2007, 01:42:54 pm »
http://www.mikuni.com/pdf/vmmanual.pdf
Not exactly the same carb but the tuning is the same.
« Reply #5 on: November 05, 2007, 02:59:17 pm »
Good info!!!!! Thanks  :)
dewjantim
« Reply #6 on: November 05, 2007, 03:34:13 pm »
If it is still to rich after adjusting the idle screw, try raising the needle jet one notch.,,,,,Dew.
c1skout
« Reply #7 on: November 05, 2007, 08:04:47 pm »
If adjustments don't seem to make a difference it may be that the "choke" is leaking or bypassing.
« Reply #8 on: November 06, 2007, 05:30:39 pm »
Enrichment device/choke I'm sure is NOT leaking as I have had it all apart to cut down the operating lever (see tech tips).
I'll give it a good go when I can to check out its new 'leaner' setting but it's getting damn bl%dy cold here in south of UK @ present!!!!
« Reply #9 on: November 06, 2007, 10:41:45 pm »
Check the rubber cap that goes over the top of the enricher.  If it travels up and down with the choke you have a problem. Even though you will swear that the enrichener is "off" it is not. The rubber boot keeps it open enough to foul plugs regularly. It is does move up and down you can secure it with a drop of super-glue. Another common problem is the float level. I think the book suggests 28mm from the gasket surface to the top of the float (with carb held inverted), but we think 25mm is better.
« Reply #10 on: November 07, 2007, 12:46:04 am »
Thanks Kevin. I know the plunger is shutting off because I 'played' with the internal spring and it snaps shut with a positive 'ping' when the lever is lifted to the off position.
The rubber boot stays in place just fine too as I have lubricated that area to avoid the lifting of it with the plunger operation.
Will look at the 25mm float level part though. Thanks!
As a secondary question do any other Bulleteers find that the carb top rests against the rear tank lug when the carb is set in the upright position? Just wondered how OK it is to set up a small air gap so carb is angled a fraction as the carb has to be able to work when the bike is angled over I know but is it OK for sustained 'straight & level' running without wearing anything?
dewjantim
« Reply #11 on: November 07, 2007, 02:58:02 pm »
Er.....I messed up......that should be lowering the needle jet one notch not raise. I'm suprised someone didn't catch me on that......Dew
Sam
  • Uralist & now, Bulleteer!
« Reply #12 on: November 07, 2007, 08:57:11 pm »
my carb needs to be rotated very slightly to miss the tank. I wouldn't expect it to be a problem, and it isn't; some carbs operate tilted down at pretty extreme angles, no big deal.
Dew; I read that as raising the clip one notch, giving you the benefit of the doubt.
« Reply #13 on: November 08, 2007, 12:46:05 pm »
Ummm, raising the clip/lowering the needle = the same difference. But, I thought these bikes were set-up to run too lean from what I have read elsewhere on this forum. Doesn't that just exacerbate the problem?
« Reply #14 on: November 10, 2007, 07:40:10 pm »
You can tilt that carb at least 20 degrees with no ill effect. Be careful when you move it that the throttle cable does not jam.
