PERLA 14 (B&W)
February 05, 2016, 06:29:00 pm
Author Topic: Electric start sprag clutch.  (Read 1062 times)
hocko
« on: October 28, 2009, 08:31:57 pm »
Hi all,
Just a quick query, is the starter motor & sprag clutch in the UCE motor the same set up as in the previous Electra engine. I'm just a little concerned regarding the reliability or otherwise of the setup. The electra's seemed to be plauged with the sprag clutch failing with regularity looking at the forums over here        ???.
Thanks
Hocko
The Garbone
  • Shade Tree
  • User Complaints: 22
Re: Electric start sprag clutch.
« Reply #1 on: October 28, 2009, 08:39:29 pm »
I don't think so....
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
« Reply #2 on: October 29, 2009, 01:17:45 am »
UCE design incorporated a modern E start from the beginning.
REA #136
t120rbullet
« Reply #3 on: October 29, 2009, 05:38:48 am »
The sprag itself is the same as the older ones. The difference is that it is mounted right on the motor sprocket and supported by a robust roller bearing.
The other difference is the UCE engine has a auto decompressor so there will be no sprag destroying kickbacks.
CJ
