I can see the problem that original spec fastener you speak of might have caused if, for example, you stopped at the road side to check on your rear light wiring. In an absent minded moment you could have finished up knee deep in Bullet parts. Yeah, it makes sense to have removed the front 90 percent of that fixing - this forum would have been overloaded with non-sprag clutch horror stories otherwise.
