Would a bad battery also cause the turn signals to flash quickly? Unfortunately do to a layoff and move my '07 bullet Deluxe had to sit quite a bit. Finally had the opportunity to ride again. Tried to kick it but no go the battery was dead so the electric starter wouldn't work. Charged the battery a bit and was able to get it started, ran fine on a short ride. Couple of days later had to charge the battery again to get it to start. When the battery was dead I couldn't even kick start it, once it was charged I could kick it on the first or second kick, usually. On saturday I went on a 50 mile ride and everything was fine. Yesterday the battery was dead again. After a 20 minutes or so on the charger I was able to kick it with no trouble. I let the bike warm up a bit then tried to take off, and the bike died. Kicked it alive again but it was running rough. Idle was erratic, usually it idles nicely. I rode it about 10 miles. I stopped and shut it of a couple of times and the electric start never worked. I was able to kick start it every time, which I prefer to do anyway. when I got home and pulled into the garage my turn signal was still on and i realized that it was flashing very quickly much faster than usual. Could that be caused by the battery being bad, or a fuse going out, or something else?
