Thanks for all the input! I really do appreciate it. let me reply to some of the posts.
1. this is now two clutch assembly's that have broken. First one broke before I ever opened the gear box. I just bought this bike 1 week ago. AARG! I was ready to do repairs but not so serious and so soon.
2. The clutch assembly came already assembled so I know all the plates were pointed in the right direction and I don't think there was any room for error because there was really only one way that it could have gone together.
3. After installing assembly I effortlessly put the gear box cover on. Nothing was jammed. The cover just slipped on and I tightened the screws.
4. I did refill gear box with EP 90
INTERESTING THINGS THAT MIGHT HELP
1. The screw on the new clutch assembly was cracked right in the middle (attached)
3. I was riding it and everything sounded good for about 20 miles
WHAT I FELT WHEN IT BROKE
1. I went to pull in the clutch and it wouldn't budge. I pulled a little harder because I was coming up on a stop light. I did not pull really hard but I did pull again harder.
2. In an instant all of the tension on the clutch handle was gone. because this just happened to me last Sunday I did not want to be stalled on the side of the road again. So instead of letting the engine die I rode it in the gear I was in (2nd) all the way back home carefully listening to make sure that there wasn't any clanking or weird noises coming from gear box.
3. Without using the clutch I carefully pushed it into neutral as I rode in to my driveway.
4. Opened up the window / cover that says "5 speed" and pushed on the clutch assembly before removing the gearbox cover. The clutch assembly wiggled as if it was broken in some way
5. I then opened up the gear box cover and as soon as I loosened it I heard and saw through the window the clutch assembly fall apart.
6. I didn't seem as if any of the parts were grinding around in there
My ignorant synopsis. I either don't know my own strength
the clutch rod is pushing back on the assembly
or something is making it so that the clutch can't move the clutch rod and I don't know my own strength and am pulling too hard.
WIERD . . . I can't be pulling too too hard because it happens in an instant. I didn't even have time to think . . . pull harder. You would think if I was pulling hard enough to crack my gear box cover that I would have to . . . stop . . . think . . pull hard. . . now pull harder . . . crack . . . crap! It happened effortlessly in an instant
