My "new" RE
May 26, 2016, 01:32:37 pm
Author Topic: wiring harness 350 bullet  (Read 1840 times)
hector
« on: October 16, 2009, 06:27:35 pm »
looking for a wiring harness for 12v 1979 350 bullet kickstart with  key next to speedometer. no idea of what is the right one. please help looked all around but none i saw seemed correct. thanks in advance
Re: wiring harness 350 bullet
« Reply #1 on: October 17, 2009, 07:13:22 pm »
i could be wrong as I am no expert in Indian market bikes, but I would suspect that a true 79 would have the key on the outside of the right hand tool box. If this is a bike that is in the US it may be a newer bike with bogus papers. In that case it is possible that a more modern wiring harness would work. We carry them (1-800-201-7472) but it will a bit of a gamble. All of the bikes sold in the US have had the key next to the speedo. The main differences are minor for earlier harnesses. What you may find is that some of the connectors changed from year to year and a few other small things like ground wires for the pilot lights. For example a UK or Indian market harness for an earlier Bullet may not have a wire for the neutral light
Ratty-matty
« Reply #2 on: May 24, 2012, 07:11:51 am »
iv got a spare one brand new ! i bought it as my wiring loom had bin hacked to bits by the previous owner as i looked mine has had alot of mods fitted ( ignition barrel in the tool box etc ) so the standard one wont fit its a spare and im willing to sell it and ship it to you if you havent got one yet
Lwt Big Cheese
  • Getting there, slowly...
« Reply #3 on: May 24, 2012, 07:16:30 am »
FWIW My domestic market '79 has ignition switch in tool box.
Not that it works with a specific key, anything will do.
No warranty implied or given.
May contain nuts.
« Reply #4 on: May 24, 2012, 06:42:03 pm »
I'm pleased to know your RE has a key.
I fully expected it to have a large toggle switch sticking out for easy access.
You chuckle at the idea but my '67 Triumph Spitfire had such a switch.
Will, really, it had 5 double throw toggle switches located side by side.
They had to be in the correct position for the ignition to be on.
As I recall it was 1 up, 2,3 down, 4 up and 5 down. (The previous owner was a bit on the weird side.)
Lwt Big Cheese
« Reply #5 on: May 25, 2012, 02:02:32 am »
I'm toying with the idea of doing away with it as anything will turn it. Lolly stick, screw driver, coin. I can't leave a key in as it would fall out whilst riding.
I saw a guy recently who had replaced it with a toggle switch. The multi position switch would be ideal.
May contain nuts.
