So, I decided to do it. I had to get to the ignition coil in a pinch and the battery was making my life difficult. So, I got it out of the way. Here is my work in progress. Comments and suggestions are welcomed. Especially if I just set myself up to explode.
So here's the plan. I took off the battery carrier and used it as an internal mount in the back left ammo can. I drilled 4 holes in the can. 1 for wires, 2 for the mounting bolts and 1 for extra ventilation. I put a 4x4 block of wood underneath the mount for added stability. I had to reroute a couple wires and you can see where I decided to use my new ground. It's the seat bolt. (Will this prove to be a shocking ride?)
I also switched to a non resister plug (NGK B8ES) and wouldn't you know it, the rig fired right up. I actually did a little dance. (Is that normal?)
pics 165, 166 are me testing the battery before the install of the ammo can.
pic 167 is all the room I freed up.
pic 168 is some weather stripping I placed on the ammo can while I had it out to reduce that banging sound, and hopefully dampen vibrations. f
more pics to follow
