Old Bill
May 25, 2016, 08:07:46 am
Author Topic: well ever since i added the flat side carb  (Read 895 times)
scoTTy
« on: October 06, 2009, 10:34:58 pm »
It won't start with the kickstarter...  maybe I'm not holding my mouth right..  sure smells of fuel though..  any ideas you folks that have made this change ???
dogbone
Re: well ever since i added the flat side carb
« Reply #1 on: October 07, 2009, 10:03:56 am »
Scotty, hard starting can be  low float level low, timing issues, or you need some Basil Haydon bourbon.
99 Enfield Bullet 535
UncleErnie
« Reply #2 on: October 07, 2009, 11:26:22 am »
If you're smelling gas, it's probably flooded.  Check to see if the plug is wet.  If so, you probbly need to adjust the needle up a notch (or down.  Shoot- I forget whichit is- less gas in the float bowl).
After you do that, but a new plug in.  This gas kills plugs.
Run what ya brung
1Blackwolf1
« Reply #3 on: October 07, 2009, 06:13:09 pm »
  I believe down leans out the fuel mixture.  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
« Reply #4 on: October 07, 2009, 08:40:18 pm »
yes; Will is correct. The best place to start is at 1.5 turns out with the air screw. Is gas flowing out the over flow tube? if so, the float needs adjusted. Which jets do you have in?  Try again with fresh plug.
            see float adjust paper below- Mike
scoTTy
« Reply #5 on: October 09, 2009, 09:42:57 am »
so far the 1.5 adj helps make the idle smoother.. thanks for the forward.. had to put on stronger glasses to read it though.. ;)
1Blackwolf1
« Reply #6 on: October 09, 2009, 09:54:31 am »
  Magnifying glasses should be sold with new jets, so you can see what the h%^& they have wrote on them.   ;D. Will.
Will Morrison
2007 500 Military
2000 Victory V92SC
The garage is full.
