Otis
May 01, 2016, 02:23:44 pm
Author Topic: Charging system  (Read 1640 times)
mrunderhill1975a
Charging system
« on: October 31, 2007, 08:16:22 pm »
For the second time in about six months my bike quit charging, the
ammeter was in the red, and for the second time I tracked it down to
corroded contacts at the rectifier. Not any severe corrosion, just a
thin film. I cleaned the contacts again and everything is now fine.
However, is there a problem with the charging system that would be
cause this "corrosion" buildup every 6 months?
scoTTy
Re: Charging system
« Reply #1 on: October 31, 2007, 09:11:27 pm »
use
http://www.royalenfieldusa.com/permatex-dielectric-grease-p-6676.html
and forget about it..  have had this N my toolbox 4 a while
StL_Stadtroller
Re: Charging system
« Reply #2 on: November 01, 2007, 09:36:41 am »
the first thing I do after aquiring any new old machine - or new new such as RE, Ural, etc.  is to go over the whole bike with dielectric grease on all the connectors I can get to, and also go over all the festeners with "green" loctite.
Ain't much more embarrasing than having one of your ridding buddies coming up to you at a stop and handing you parts that fell off your bike they stopped to pick up for you.  :-[
Brian Wittling, St. Louis, MO
Member Emeritus
https://www.facebook.com/brian.wittling
RagMan
  • Bulleteer, Uralist &
Re: Charging system
« Reply #3 on: November 01, 2007, 01:04:48 pm »
That would suck. So far, I have not dropped anything I did not see fall off. (I hit a rock off road, after coming off the trail into a deep wash, with the Ural, and the left hand muffler was knocked off)
aka Indiana Bulleteer.
Jefferson County, WA
dewjantim
Re: Charging system
« Reply #4 on: November 01, 2007, 05:10:45 pm »
Honda also makes a good dielectric grease.....Dew.
